Home › Forum › Ask A Member › Wico coils IT RUNS!!!
Viewing 10 posts - 21 through 30 (of 30 total)
  • #22120
    mini-motors
      And I can see that slit in the drawing on the Elgin website, so I know just where to poke. But water needs to be coming out the leg as well, right?
      #22130
      mini-motors
        And….no. Poking didn’t solve the issue. So, I’ll be spending the day disassembling it AGAIN to find the clog. Actually, I haven’t had it that far apart as of yet, but the day is young.
        #22132
        mini-motors
          I am curious why it stalls. It’ll run for about 20 to 25 seconds, sneeze, and die. It will start right back up, and I don’t want to push it without water flow, but I’d still would like to know.
          #22137
          mini-motors
            And while I’m waiting for it to cool(or dreading , your choice), I’d like to ask a couple more questions. First, what is this fitting on the bottom of the head? The donor motor just has a simple plug.
            And what is this small hole for? This is a pic of the donor motor, of the top of the leg where it fits the bottom of the power head. I looked at the corresponding hole on the block, and it is just a cavity that seems to go nowhere.
            Thanks again.
            Stan
            #22148
            jim-moffatt
              THE FITTING IS POSSIBLY A FLUSH PLUG. Does it pass water? Only the 2.5 hp single model should pass water
              Some models drained some of the crankcase fuel to lube the swivel tube. Others didnt. I think the hole is for lubing the swivel.
              #22156
              mini-motors
                I don’t know if it passes water. I’m going to disassemble most of the engine, except the head and cylinders/crankcase. I will blow air in there and see where it comes out. My goal is to make sure all water passages are clear. While I’m in there, I’ll replace all the gaskets. I had re-used all of the intake gaskets, as they were mostly intact, and I didn’t have the gasket paper to make new. But when I got to the lower unit, I was forced to get some. There are water jackets on the left side which will require 2 gaskets, and something on the right side.
                #22160
                jim-moffatt
                  Beware of removing the left side exhaust covers. The screws almost always break. They go into the water jacket. You should not have to remove them.
                  #22171
                  mini-motors
                    But it seems to me that there’s a clog in the cooling system. How do I go about clearing it?
                    #22250
                    mini-motors
                      Update. I took it apart again, except for the side covers. I did remove the powerhead as to get to the water lines and blow compressed air through. That fitting on the bottom of the cylinder head does pass water(air), so it may be a flush point. I may have to make something to go there, as I will be using the motor in salt water, and I don’t want to leave it in storage all salty. I cut new gaskets for the carb and reed block, as well as the powerhead/lower leg. While I had it apart, I was able to reinstall the lower unit to the leg whilst the leg was upside down. There is a small brass plate that may have been in wrong, due to not being able to see it correctly, but reassembling it upside down allows for gravity to help, and a clear line of vision.
                      It’ll be a day or two before I get to put it in a bucket of water and fire her up, but I am hopeful that it is right.
                      #22376
                      mini-motors
                        The good news is that it pumps water like a champ. The bad news is I can’t keep it running. I think I have to overhaul the carb again. I think I missed something.
