Home › Forum › Ask A Member › Wico coils IT RUNS!!!
Viewing 10 posts - 1 through 10 (of 30 total)
  • #2254
    mini-motors
      I got the flywheel off the Elgin today, and found this’
      Does the integrity of the coating (rubber, plastic?) have an impact on their function? Can I just wrap them in a good electrical tape and, as a former boss would say, "race on it"? I do have the missing chip. I just left it out of the picture for clarity.
      Thanks.
      Stan
      #21983
      JOSEPH BRINCAT
        those coils are "shot" … moisture intrusion = corrosion
        #21984
        mini-motors
          Let’s hope the donor motor doesn’t suffer from the same issue.
          Thanks.
          #21987
          ken-w
            These can be replaced with OMC universal coils, just replace the coil and not the metal.
            #21989
            mini-motors
              I have a second, almost complete motor, same model and all. My original hope was to get both running, but the one is too far gone. I’m having trouble getting the second, or "donor" flywheel off. I don’t have a real puller, but I used a homemade one to get the first one off. So, I hope the donor unit has good coils. But if not, I saw on the Oddjob Motors site the thing about OMC, or Sierra coils fitting right in. I found the Sierras for about $20.00 a piece.
              I’m still hopeful.
              #21990
                If you get real lucky the donor motor may have the old orange shellac coils. Those things are bulletproof.
                #22001
                mini-motors
                  Yea….I usually don’t have that kinda luck. But time will tell. I dug out a torch to apply a little heat to get that flywheel off.
                  I had another thought at dinner. I have a Sea King(Gale) 5 hp twin. It has bad rod bearings, but it might have the Wico coils. And I’ll bet that flywheel will come off a lot easier. I’ll try the torch first, but if that doesn’t work….
                  #22002
                    I’m thinking your Sea King will have this style mag and coils in it.
                    #22011
                    mini-motors
                      See what I mean about "luck"?
                      #22014
                        Or. Depending on year, they may look like these:
                        adult photo sharing
