Home › Forum › Ask A Member › Using a car coil outside the 2 stroke block
- This topic has 31 replies, 14 voices, and was last updated 10 years, 1 month ago by
jw-in-dixie.
September 15, 2016 at 2:51 am #44056quote Tom Manley:I was trying to ease into this topic, but that may not have been the best approach…
If the original coil is still in place, and just has a bad secondary, there is an alternative to the battery system. If you have a coil with a bad secondary and you try to start it, you’re still generating current in the coil primary circuit. You can use that current to fire another coil mounted externally. Detach the wire that normally goes from the coil to the points, and add on some wire to extend it out from under the mag plate. Attach it to the primary lead on an OMC Universal coil, and mount the coil on the block of the motor with the OMC coil ground wire grounded to the block. Then run a spark plug wire from the OMC coil to the spark plug. This may work better if you remove the bad secondary from the bad coil, I can’t remember whether I did that.
Tom
Now this is a really clever idea. Even if one had to get some magnet wire and wind a new primary it’s good. It might be made to work with various other coils.
September 15, 2016 at 7:41 pm #44099Be sure to match the cap to the coil, use the condenser that came with the factory coil to save the points contact area.
September 15, 2016 at 7:53 pm #44103Back about 1975-1985 I used to replace the oem coils with Kmart universal coils and mounted the caps on the coil bracket on many snowmobiles before cdi came out. I used caps from a 1969 chevy impala. Worked great.
September 16, 2016 at 8:15 am #44135I tried using an external coil connected to the old coil in the magneto. It didn’t work out. I think if there were enough turns left on the secondary side this may work out better. There would enough voltage to kick back to the primary side of the coil to fire the external coil. One of these days I would like to try this out again to see if this would work.
September 16, 2016 at 10:01 am #44136Interesting, we STILL don’t know what motor he has…..
classicomctools@gmail.comSeptember 16, 2016 at 12:24 pm #44138A "Boathouse Repair" is one thats done without having tools or the skills to do it properly.
This reply was modified 8 years ago by
Tubs.
Tubs.
September 16, 2016 at 12:31 pm #44140Or someone could have sent him a known good correct coil, that was where I wanted to go, but oh well 🙂 Morning Tubs 🙂
classicomctools@gmail.comSeptember 16, 2016 at 12:33 pm #44141Hi Buddy 😉
September 17, 2016 at 1:20 pm #44171Just had a thought – wonder if the COP (coil on plug) that Ford uses would work on an OBM? They are relatively cheap, like 8 for $30 on the bay. Hmmmmm,,, JW
September 17, 2016 at 6:21 pm #44185quote jw in dixie:Just had a thought – wonder if the COP (coil on plug) that Ford uses would work on an OBM? They are relatively cheap, like 8 for $30 on the bay. Hmmmmm,,, JWI wondered about this too. But most COP coils seem to be long to reach down into the plug wells, and most outboard plugs are pretty close to the motor cover. What about "coil near plug" coils?
