Home › Forum › Ask A Member › Using a car coil outside the 2 stroke block
- This topic has 31 replies, 14 voices, and was last updated 10 years, 1 month ago by
jw-in-dixie.
September 13, 2016 at 6:56 pm #5249
How do you hook up a car coil…to provide spark for a johnson?? run a + wire to the points..then to the coil?
September 13, 2016 at 7:14 pm #43980Which motor are you trying to run it on?
classicomctools@gmail.comSeptember 13, 2016 at 7:23 pm #43982Connect battery ( – ) to ground, Ground the coil to block, connect battery ( + ) to coil +, connect coil – to points, unhook motor coil and leave condenser connected. Put a switch in the + circuit and depending on the coil used you may need a ballast resistor. If this is a two cylinder with two points , you will need two sets of coils.
September 13, 2016 at 7:29 pm #43984Johnson coils are dirt cheap….. so which motor???
classicomctools@gmail.comSeptember 14, 2016 at 1:44 am #43995September 14, 2016 at 10:44 am #44002As they say a picture is worth a 1000 words
September 14, 2016 at 11:42 am #44004I think we still need to know what model. Or at least, whether the points are normally closed and open to fire, or normally open and close to fire.
If they are normally closed and open to fire, you wouldn’t want the coil energized without the motor running.
Tom
September 14, 2016 at 12:01 pm #44005quote Tom Manley:I think we still need to know what model. Or at least, whether the points are normally closed and open to fire, or normally open and close to fire.If they are normally closed and open to fire, you wouldn’t want the coil energized without the motor running.
Tom
What?
BnC
September 14, 2016 at 12:37 pm #44007quote collectorinspector:quote Tom Manley:I think we still need to know what model. Or at least, whether the points are normally closed and open to fire, or normally open and close to fire.If they are normally closed and open to fire, you wouldn’t want the coil energized without the motor running.
Tom
What?
BnC
Some motors fire when the points open, other fire upon closing of the points..
classicomctools@gmail.comSeptember 14, 2016 at 2:07 pm #44010 -
