Home › Forum › Ask A Member › Ugly Duckling
Viewing 10 posts - 51 through 60 (of 75 total)
  • #54231
    bullie
      I guess that is possible. I do not see where it has broken off if that is case.
      I have already done something very dopey this evening and I suspect this might be dopey 2.0. I am sure it is something simple that I just don’t understand well enough to recognize.
      #54236
        YES – The pin is a single piece. It is the same material as the shaft so when sheared, it is very hard to spot. Worse, when sheared it may distort the hole making it hard to drive out. Best use a brass shear pin when you get it properly back together. . . πŸ˜†
        #54238
          quote Garry in Tampa:
          Just so there is no misunderstanding, Garry means the brass shear pin in the prop. The pin in the gear is not supposed to shear, being harder material than the prop pin.
          #54239
            Absolutely brass shear pin in the propeller. If that had been done originally, the drive pin in the gear would have never sheared. . . πŸ™„
            #54242
            bullie
              I actually feel a little better about it now. I expected to be proven a little dopey again but having someone with so much knowledge tell me that it is hard to see, well, that makes me feel a bit better. 😳
              This little motor has been a trial. It runs so good now though. I hope I can get the spinny part moving. πŸ˜€
              How should I go about removing the 3 pieces of pin?
              #54245
              fisherman6
                Glad to see we are on the right track with this one. I’m assuming the pin pieces in the gear are more clearly visible and no too difficult to drive out. The one in the prop shaft has to be found first. Once it is found, I woulove clamp it firmly in a vise with soft jaws so to not damage the outside of the shaft. Once it is secured, I’d use a center punch as near to the center of the pin as.tough can see and give it a whack. Once it starts to move, go to a pin punch a little smaller than the hole and finish driving it out. Finding the pin may be the hardest part.
                -Ben
                OldJohnnyRude on YouTube
                #54256
                  The clue is that it was drilled at the same time as the cotter pin hole. So that and the polished part where the gear was should get you close to were the pin was. . . πŸ˜‰
                  #54264
                  kevinrude
                    i have a couple Montgomery Ward (Sea King) motors identical to that one. Strong runners. Garry Spencer once called them the best single-cylinder engine OMC ever produced.
                    #54266
                    bullie
                      Thanks Ben and Garry. After only smacking my finger one time I drove the 3 parts of the pin out. A major success. So, now I need a new pin #550669 and a brass shear pin. Anyone know a source for the pin?
                      #54268
                      fisherman6
                        Great news! Glad you got all the pieces out. One thumb-smasher is probably better than I’d have done. 😎
                        Do you have a micrometer or dial caliper or some way to get an accurate measurement of the pins? Someone may have the real OMC replacement parts, but if.you have a metal supply shop anywhere near you, you should be able to get stainless and brass round stock in the diameters you need and just cut them to length and deburr the ends and put them back in. If you don’t have any place to get the stock, let me know the sizes of the pins and I’ll make you new ones. πŸ˜‰
                        -Ben
