Home › Forum › Ask A Member › Ugly Duckling
Viewing 10 posts - 21 through 30 (of 75 total)
  • #47969
      The 580084 coil used in the Evinrude Sportsman and Sportwin can also be used and is available through Doug Penn. . . πŸ™‚
      #47974
      cajuncook1
        quote Bullie:
        quote cajuncook1:
        quote Bullie:
        I decided to revisit this little jewel. No spark. I pulled off the tank and the flywheel. I believe the coil is bad. What do I need to look for?
        Just looking at the coil does not indicate if the coil is good, unless the covering is cracked and peeling.
        Doug Penn did a nice job of explaining how to use a analog meter to test if the primary and and secondary windings of a coil are good.
        https://m.youtube.com/watch?v=KT8rk5QWgS0
        This test is exactly what I have stated that I did to determine the coil was bad.
        Excellent, just making sure πŸ™‚
        #47978
          #47988
          PugetSoundBoater
            that video by Doug Penn was very good. After doing a few tests i should have it memorized. Thick skull= takes a while
            Robbie Robertson
            #48004
            bullie
              quote pugetsoundboater:
              Me too. I have checked and rechecked myself. LOL I will have to find a coil for it now. Looks like they pretty dear though.
              #49261
              bullie
                Ok. I acquired a coil from a club member and I have some free time coming up. Recipe for confusion!
                The coil has a couple of inches of plug wire attached. I am wondering what the best method of attaching a new wire would be? Soldering? One of the crimp on butt connectors?
                I am very bad at soldering. Mainly because I know nothing about it and in the past I basically tried to use it like a hot melt glue for metal. This doesn’t work well. I seem to wound myself with the iron regularly too.
                #49263
                Steve D
                  quote Bullie:
                  Hahaha! You crack me up Bullie! πŸ˜† I can do some stuff well, but soldering, welding, electric, haven’t been there yet! πŸ˜•
                  #49266
                  bullie
                    quote Steve D:
                    quote Bullie:
                    I have been quite honest about my electrical learning disability. I guess 40+ years of my father telling me to leave that stuff alone stuck. I am working on it too. In fact, I just watched 3 or 4 videos on YouTube about soldering. Did y’all know that pipe solder and electrical solder ain’t the same? 😯 I am learning lots already.
                    #49272
                      Yeah, I learned about different solders at the ripe old age of about 12 when I built a one-tube radio using acid core solder. The only kind of solder the local hardware store had. The whole radio chassis turn green corrosion in just a few days. By some miracle, the radio worked anyhow.
                      #49298
                        Gale Products built that for Atlas under the Royal label. Evinrude used the powerhead in its 1948 through 1951 model 4425 Sportsman. That ignition was used on the 3.3 HP model 4423 Sportwin of those years also.
                        Sportwin Ignition –
