Home › Forum › Ask A Member › tn 28
Viewing 10 posts - 11 through 20 (of 23 total)
  • #199597
    GARY STEFFENEY
      aquasonic I have looked all over it and the paint is the same color, from block to lower unit and looks factory to me,,,thats what is messing with me,,,i have repainted myself and I can’t see anywhere they missed as usually happens,,but I gguess stranger things happen,, I will go further and see what turns up,,thanks for replay,,,,
      #199655
      JOHN HOLBIK
        Just a thought are they both built in USA maybe one is Canadian.
        #199659
          Pretty sure I’ve seen both color variations, but don’t
          know the “rhyme nor reason” behind it. Maybe I’ll
          gander around the motors today and see if I have both.
          GARY STEFFENEY
            john hmmm hadn’t thought of that angle,,, i’ll look , will their be a Canadian marking on them and where would it be,,,,an thanks for idea
            #199727
              I looked around my outboard stash “here and there” today,
              but did not find the motor I was thinking about that was
              the off color green. I’ve given away about a dozen of
              the TD’s / TN’s over the last couple of years, and that
              was probably one of them.
              Hopefully someone can confirm if there’s a Canadian connection, eh?
              GARY STEFFENEY
                going out to garage in few and check it out more,,,,lots of good ideas see which one wins,,,,,thanks,,
                #199732
                  If one of your motors was a Canadian made model, the serial number range will be 119368 thru 135972 for the 1952 model year and 135973 thru 153937 for the 1953 model. The motor on the right in your picture definitely looks like faded Seahose green paint but the motor on the left really doesn’t look like either Seamist or Seahorse green.
                  1982 Evinrude 25hp
                  • This reply was modified 6 years, 7 months ago by Bob Wight.
                  #199775
                  GARY STEFFENEY
                    update on tn 28 on the light color one ser nr is 063385 on the darker color one ser nr is 949961
                    #199931
                    GARY STEFFENEY
                      hi ser nr on the light green one is 063385 and on the dark color one is 949961
                      #199949
                      JOHN HOLBIK
                        The model tag will say Peterborough theUSA will say Waukegan.
