Home › Forum › Ask A Member › tn 28
Viewing 10 posts - 1 through 10 (of 23 total)
  • #199519
    GARY STEFFENEY
      i have acquired two tn 28 Johnson outboards 5hp and they are different ,, as in color and decals,, was there a change in the years they were made,,,,thank you,, one is light green and one dark, one has yellow dedals and one white,,,
      #199520
        TN28 was produced in 1952 and 53, but the original factory paint colors would have been the same for both years. The decals for both years were similar, but not identical, for both years. Both years decals were primarily white, but they may have yellowed with age and UV exposure.
        1982 Evinrude 25hp
        • This reply was modified 6 years, 7 months ago by Bob Wight.
        #199524
          1952 serial numbers were 920480 through 980883; 1953 were 980884 through 1,079,711
          #199528
          GARY STEFFENEY
            bob thanks I thought that too but decals are pretty nice and the yellow ones hve a red accent and the white are all white, if you have a text nr. I could send pic and let you look ,,maybe you see something I didn’t,,,
            #199530
            GARY STEFFENEY
              frankr. thank you I will check them very soon,,,still puzzeled on color and decal,,, but will see
              #199531
                  Gary – got some pics of each motor you can post here so others can weigh in?
                  1982 Evinrude 25hp
                  #199536
                  LLOYD LAUTNER
                    Early TN’s were lighter Seamist Green and later TN’s were the darker Seahorse Green. I can’t remember the year they changed color at this moment. You will surely need new Leather Primer Seals and installation instructions to get them started. Might also need to make new floats. If so give me a call. I am in Northern Michigan. 231-929-7479
                    #199540
                    GARY STEFFENEY
                      Resized9520200405951522289551642305843009221226186
                      these are the two I have
                      #199549
                      aquasonic
                        In 1952 Johnson started using Seahorse Green. The TN in the foreground looks to be Seahorse Green, but the one in the back looks like a repaint. You should be able to tell when the lower cowl is removed.
                        Improvise-Adapt-Overcome
