Home › Forum › Ask A Member › Soaked the Kf7
Viewing 10 posts - 21 through 30 (of 31 total)
  • #262353
    Mallett
      C5F0C1CB-6DDE-4A08-8A72-A8DF3195730D
      Now I have a new puller. So just keep tightening, and it pops off?
      #262356
      Mallett
        Yup it pops up
        #262357
          Being that is a steel
          flywheel you’re probably OK but that is not the
          best way. Distortion of the flywheel is Possible.
          Those 3 threaded holes in the flywheel are
          there for a reason.Its off now keep going on.
          #262358
          Mallett
            All sprayed with crc  wire dryer
            #262360
              Sounds like a good option. Use what you got.
              #262361
                Heading out for dinner but I don’t think you
                need me anymore. Once you have spark again
                just put everything back where you found it.
                You Done Good!!!
                #262362
                Mallett
                  Thanks so much tubs. Enjoy your dinner and happy fourth!
                  #262365
                    Guess you got the flywheel off OK, but as Tubs noted, you really shouldn’t use a jaw type puller on the rim of the flywheel.   Also, whenever you need to remove the flywheel, leave the flywheel nut installed loosely near the top of the crankshaft threads.   That will help prevent the center bolt on the puller from mushrooming the crankshaft threads when you tighten the bolt.  And if a flywheel is really stuck, leaving the nut on there loosely will help prevent the whole shebang from flying off when the flywheel finally does break loose.   Good luck with getting it running again.
                    1982 Evinrude 25hp
                    #262383
                    Mallett
                      Well if my phone wasn’t at the bottom of lake x, I would be able to show you all a great ride after  of drying her out! I returned to the scene of the crime. It fired up after a few pull’s , sputtered a wee bit then off I go! As billw suggested I ran it hard for a tank full.
                      so now I can look for a flywheel puller set at the yard sales.
                      Thanks again for your time and your willingness to help, much appreciated!
                      #262384
                      Mallett
                        Great story dale, those were the days. That’s what’s great about this stuff you can make it run with out need a computer.
