Home › Forum › Ask A Member › Soaked the Kf7
Viewing 10 posts - 1 through 10 (of 31 total)
  • #262297
    Mallett
      So out today running around today, the chop was heavy and a lot of large boat wake. I surfed down the back of a wave, another hit the port bow burying it. Over and turtled!  So what’s the first thing? Empty the fuel tank, drain the carburetor, take the spark plugs out, take off the covers to see the pistons use  air compressor to blow out to dry, what’s  next, call Dave?
      Thanks
      #262298
        lube the inside get spark and start as soon as posable.
        #262307
          Agreed. And once it’s running, get it back on the boat and run it hard. It takes more time running than you think to clear the crank shaft bearings of every trace of water.
          #262310
          Mallett
            Hay Dave, Billw, Lube the inside of the pistons, and do the other things that I listed? Thanks
            #262315
              Plugs out-
              Pull it over to get water out-
              Lube cylinders-
              Drain tank and carb-
              Dry out ignition and get spark.
              Get it running.
              “As soon as passable!!!!! ”
              Many will tell you to keep a motor
              submerged if you can’t get to it
              right away.
              #262327
              Mallett
                Working on it now, just broke spark plug 😖 off to the parts store. How do I get spark?
                #262330
                Mallett
                  What lube should I use on the pistons? I’m turning the flywheel by hand no spark
                  #262332
                  Mallett
                    Should I use the shop vac to suck and blow it out?
                    #262335
                    Mallett
                      How to dry out the ignition?
                      #262339
                        Flywheel needs to come off.
                        Dry out the ignition. If you have air us it.
                        Once dry spark should reappear.
