Home › Forum › Ask A Member › Shift shaft o-ring plug
  • #41450
      I was wondering the same thing as Rick, perhaps the gasket got double stacked, or missing.
      #41451
      RICHARD A. WHITE
        quote rickrodt:
        Did you install or replace the gasket that goes in first? First the gasket, then o-ring and finally the brass bushing. Part number 304764 should be the part you need. I also believe that the brass bushing has a recess area where the o-ring sits. The smaller motors just use the o-ring and bushing, no gasket.
        http://www.marineengine.com/parts/johns … n=Gearcase
        Yuppers, even cleaned around the brass plug.
        I will apply sealer around the perimeter this evening and see how that does..
        Thanks to all
        classicomctools@gmail.com
        #41479
        RICHARD A. WHITE
          quote Chris_P:
          I put a ring of 3M 847 around the circ of the brass before I tap it in.
          Looked in 5 different places, where so you buy this stuff????
          I use Quicksilver Bellows adhesive normally..
          #41481
            I buy mine from the BRP dealer, but it can be had online, I think stores like Fastenall as well. Fantastic product, one anyone that works on motors should have in his toolbox.
            Sealing gearcases, impeller plates, crank halves, fuel fittings, you name it.
            #41497
            fisherman6
              I bought mine on fleaBay. It is very good stuff. A tube goes a pretty long way. Not sure how the shelf life is though once the seal is broken.
              -Ben
              OldJohnnyRude on YouTube
              #41504
                I got mine from McMaster-Car.
                http://www.mcmaster.com/#3m-847-adhesives/=13k2489
                Steve A W
