Home › Forum › Ask A Member › Shift shaft o-ring plug
- This topic has 15 replies, 7 voices, and was last updated 10 years, 3 months ago by
Anonymous.
August 1, 2016 at 10:51 pm #4896
Resealing a gear case that had some issues, I have one leak. It leaks around the outside of the brass plug that holds the shift shaft o-ring.. Thoughts on something to seal that? For what are obvious to me reason I do not want a permanent seal so that should the next guy, (possible me), would need to be able to get it out..
So what can I use…???
classicomctools@gmail.comAugust 1, 2016 at 11:23 pm #41429I put a ring of 3M 847 around the circ of the brass before I tap it in.
August 1, 2016 at 11:28 pm #41430Well that is nice, but it is already assembled, and no leaks but there…some paint around the edges?
classicomctools@gmail.comAugust 1, 2016 at 11:35 pm #41431Try tapping it down a bit further to compress the o ring a bit more.
August 1, 2016 at 11:41 pm #41432I seated it pretty good the first time, then got serious after finding the leak, it won’t go any further south…going to try some paint….
classicomctools@gmail.comAugust 1, 2016 at 11:49 pm #41433I don’t envision paint would last very long in that environment on that surface. Strange leak. What motor is it?
August 2, 2016 at 12:02 am #41434OMC 72 18 hp…
classicomctools@gmail.comAugust 2, 2016 at 1:05 am #41440I have trouble seeing paint doing it in that environment as well. You don’t have anything to loose by trying it though. I would be more apt to think some kind of gasket maker would stand a better chance in there. Maybe try the paint first and if it gives up try something like form-a-gasket applied around the top of the bushing. Not sure if that will work either but it’s something else to try.
The last gearcase I re sealed was on my ’62 Johnson 5.5. It leaked at the shift rod o-ring and around the bushing as well as prop shaft seal, drive shaft seal around the shafts and the seal bores, the vent plug washer and the drain plug washer. The only thing that didn’t leak was the spaghetti seal. Everything got a good dose of 847 on that one. It’s good now but after that one, everything will always get coated with sealant when resealing a gearcase. It leaked everywhere. With about 6psi in the gearcase there were bubbles coming from places I never thought about having leaks.
-BenOldJohnnyRude on YouTube
August 2, 2016 at 1:39 am #41443Did you install or replace the gasket that goes in first? First the gasket, then o-ring and finally the brass bushing. Part number 304764 should be the part you need. I also believe that the brass bushing has a recess area where the o-ring sits. The smaller motors just use the o-ring and bushing, no gasket.
http://www.marineengine.com/parts/johns … n=Gearcase
August 2, 2016 at 1:46 am #41445Degrease it and apply a light coat of your favorite epoxy to it. I’ve had to do this on salty motors and it will break off if you need to remove the bushing. A bit of green Loc Tite bearing retainer on it before assembling would be better though.
