Home › Forum › Ask A Member › Ruddertwin Jugs
Viewing 8 posts - 31 through 38 (of 38 total)
  • #63762
    RICHARD A. WHITE
      Yeah, I tried to unscrew mine as well… it did not break and then Chris stepped in and got me down the correct path of enlightenment
      classicomctools@gmail.com
      #63774
      ian
        Thanks Richard and Tubs, great info, I was scratching my head on that….
        As Wayne said someone has had the knob out before on this flywheel. After cleaning I noticed that there are cracks. Fortunately this is from the incomplete parts motor. The other one has not been touched. I’m trying to salvage everything from the parts motor before I touch the model "c"
        #63777
          Ah shoot, dreaded cracked flywheel.
          I think I tried to unscrew mine for the first time for about half hour before I gave up !
          #63778
          ian
            Some nice details…
            #63780
            ian
              Parts motor, some pieces are cleaning up nicely.
              #63781
              ian
                I am wondering what year the rudder and steering bracket. The fitment of the taper is different.
                #63801
                  I’m finding that the small hole flywheels
                  are the ones that are often cracked.
                  Their is a taper on the nut as well as the
                  crankshaft and even though it says
                  "Keep Nut Tight" it would seem if you
                  overdo it they can crack.
                  #63854
                  ian
                    Didn’t know that there is different size taper fit. It’s interesting that they switched to that safety flywheel… I’m not sure how many knuckles that saved. 😉
