Home › Forum › Ask A Member › Ruddertwin Jugs
Viewing 10 posts - 21 through 30 (of 38 total)
  • #54898
    fisherman6
      It was a nice meet. I did see there were some Canadian chapter members there. Too bad you didn’t make it. At least you got some work done.
      -Ben
      OldJohnnyRude on YouTube
      #63686
      ian
        Where did you get the jugs plated? Tank too? I have to do my ruddertwin as well…
        #63697
          I got them done at Mayfair plating in Toronto.
          #63720
          ian
            Thanks I’ll look them up. I have to figure out how to get the starter knob off the flywheel.
            To me it looks like the flywheel nut, flywheel, tank and jugs were the bits nickel plated. Was there anything else?
            Looks like the copper lines and bolts were zinc plated. Perhaps the bronze steering mount as well?
            Was anything painted?
            #63726
            RICHARD A. WHITE
              The starter knob is driven out from the bottom, ensure the driver is smaller than then screw. Flip the flywheel upside down leaving clearance for it to be driven down. When installing push the knob in from the top and use a ball peen hammer to "flare" the flange out to hold the know in place.
              classicomctools@gmail.com
              #63727
                Here is a picture showing what Richard
                has described as to getting them out.
                The bottom pictures show what is inside
                and how they were put together.
                #63731
                  Not sure if the transom screws would have been plated at all as well? I just polished mine and they turned out nice.
                  After paying for the tank, and jugs, I polished the rest! I am going to do my flywheel as well though, and nut. They don’t last long not plated. I told Wayne today I can bring the parts in for you guys as I am working nearby.
                  #63749
                  WAYNE
                    That is not how I expected the starter knob to be removed. Ian knocked it out tonight. Someone must have removed it once before as it came out with little effort.
                    Wayne
                    Upper Canada Chapter
                    uccaomci.com
                    #63752
                    RICHARD A. WHITE
                      Tubs picture shows what happens when you logically think that it would unscrew… like I did the first time…lol Then I believe it was Chris Scratch that advised me on the proper way to remove them.
                      #63760
                        I learned how to get them out from Richard. I think
                        everybody who wanted to take one out first tried to
                        unscrew it. That’s what I did. The slot would seem
                        to indicate that is how it was assembled. This part
                        may have been designed on April first. 🙄
