Home › Forum › Ask A Member › Row boat motor ID
Viewing 10 posts - 11 through 20 (of 32 total)
  • #295920
    fergalb
      Another question for you wise ones, the arms on the transom bracket are broken off they may not have been original but I can’t seem to find an image of one to copy so if any of you have a RBM could you share a photo and give me the length of the arms. Cheers
      #295940
         These help you any?
        RBM-1
        RBM-2
        #295944
        fergalb
          Thanks Tubs I can work off them, looks like I can make it out of one piece of flat steel and when in the down position it will extend about an inch past the exhaust can, might have to make a jig to get the bend 🤔 Thanks again I’ll plod along with it. The coil is shot so I will build a buzz box instead of trying to fix it.
          #295961
          fergalb
            Another question 🙂 this was in the box of bits it was full of grease,  it looks to have been repaired at some stage and has a lot of brazing done on top with a square hole would there have been a grease nippel here 🤔  sorry for all the question this is my first time seeing one of these motor’s.
            #295966
              We are here for people to ask questions. That is the top main bearing lubricator. You fill it with grease and give it a twist every once in a while. I don’t have this motor anymore. This is the best picture I have.
              T@
              #295992
              fergalb
                Do you know if there is ment to be a grease nippel on it or do you just pack it up by hand, Thanks again.  Getting there with the bracket it’s not as strong but will not get much use.
                #296000
                David Bartlett
                  You would pack it full after removing the cap, then when you screw the cap down it forces  a bit of grease out the end. A half turn or so every now and then.
                  David Bartlett
                  #296143
                  fergalb
                    Another question for you wise ones,  on the little cam for the water pump there are holes that line up but the inner shaft is partly blocked and the outer one there is only a hole on one side, should there be some sort of pin or ball-bearing, cheers
                    #296186
                      No pin or ball. I believe the holes are there to let water pass through as it goes up and down moving the piston in the pump .
                      #296212
                      fergalb
                        Thanks again Tubs, I have another holey question,  in the outer tube there’s a hole that lines up with a hole on the main shaft that appears to be treated should there be something in it 🤔  I hate fixing things that someone else took apart.  Also if anyone could point me towards a good restoration link or video showing all the parts or a parts list and drawing that might help stop me asking all these questions  🙂
