Home › Forum › Ask A Member › Row boat motor ID
Viewing 10 posts - 1 through 10 (of 32 total)
  • #295646
    fergalb
      Hi all it’s been a while but back again with another question 😀 I picked up this RBM but it has no ID tag on the tank I think it might be 1922 but would like some conformation, is there any other way to tell the year, Thanks
      20250417_122543
      #295648
      fergalb
        It has a coil under the flywheel and a 1″ 1/2 fuel cap.
        20250417_122644
        #295663
        JOSEPH BRINCAT
          Your garden variety Evinrude “A” , with the reversing lower unit. Interesting modification to the tiller handle, I suspect to afford a better grip to twist the tiller handle into F or R mode.  Mid 1920 ‘s I would guess.
          #295667
            Going by the gear case it’s earlier than 1920. I’m not very knowledgeable on these. I believe that gear case was used from 1913 to 1919. If anybody tells you different – you should listen to em.
            #295669
            fergalb
              So I’m still OK if I order these decals and plate from American outboards.
              #295684
                I believe your good with both.   You have the rest of the parts?
                #295685
                PM T2
                  Its 1922 or earlier because its a RH rotation prop lower unit. Hope this helps.
                  Best,
                  PM T2
                  #295686
                  JOSEPH BRINCAT
                    PM T2, Good catch on the prop rotation.. that’s why we keep ya’ around
                    Thanks,
                    #295687
                    fergalb
                      Thanks guys I’ll push on so with the restoration, I did get a box of bits with it and it seems to be all there the fuel tank is in bad shape full of holes that will need brazing, the tilt arms are missing off the transom bracket looks like they were riveted on so probably not original but easy to make new ones. I haven’t tested the coil yet but hopefully I can get it going again, the keyway was snapped in half so hopefully that was the only reason she was put away. Thanks again. 👍🏻
                      #295691
                        Prop
