Home › Forum › Ask A Member › Re: johnson lt-10
  • #56140
    lakeofwoods
      Got spark on both plugs now ! Thanks for the help ! Won’t run in water barrel but runs on saw horse . One hurdle at a time I guess Lol
      #56142
      lakeofwoods
        Got spark now on both plugs . Thanks for the help! Won’t run in barrel with water but will start on saw horse . One hurdle at a time Lol. Thanks
        #56144
          That could be an indication of low crankcase compression. Have you run a compression test? ❓
          #56146
          lakeofwoods
            Never put the compression tester on it . Just pulling it over can tell both cylinders feel like there is lots of compression. When it did fire over in tank water was leaking out at base gasket where power head attaches to bottom end. Could see where water was coming out of gasket . Thinking maybe some water getting in crank case maybe . Actually looked like moisture on the plugs . Think that’s possible ?
            #56147
            lakeofwoods
              Was running 25-1 oil . What do you think ?
              #56157
                I’d feel safer using 16:1.
