Home › Forum › Ask A Member › Re: johnson lt-10
  • #6740
    lakeofwoods
      As you can see it sparks across the top with the spark tester. It does eventually spark in the window as well though.
      lakeofwoods
        The tester
          That looks normal to me. It indicates the resistance across the gap in less than the resistance of the tester. The voltage being developed should be enough to fire the plugs. If one plug does not fire, it is a short or open circuit in one of the external high voltage wires or hardware. . . ๐Ÿ˜‰
          #56094
          lakeofwoods
            Okay so if I pick up some plug wire and caps it should jump the plug before that gap ?
            #56095
            lakeofwoods
              any idea looking at the picture which side fires top plug ? the wires were cut off when I got it .
              #56100
                Turn the flywheel so one piston is at top dead center. Measure the resistance of the spark plug wires. The one with the highest resistance is the one that goes to that cylinder. One spark plug wire measures the coil resistance, the other is shorted by the distributer brush and does not. . . ๐Ÿ˜†
                #56107
                  Good tip Garry. I was just wondering the same thing on the HD-15 Johnson I was
                  working on today. I eyed up the grounding contact in the flywheel as I put
                  the flywheel on, with the top cylinder at TDC, then decided which end of the coil
                  should be "top". Funny, but later on I found my diagram where I noted which
                  side of the coil was "top" (according to the plug wire band) and it
                  was opposite of what I guesstimated. I’ll try your Ohm meter method
                  tomorrow!
                  lakeofwoods
                    I will have to put some new plug wires on it with caps and see if it has spark at the plugs . With the spark tester it sparks up at the coil as seen in the picture but with my meter it shows a open on both sides of the coil on the secondary coils.
                    #56127
                      It would show open to ground from either end of the coil unless the other end was grounded. . . ๐Ÿ˜€
                      #56132
                        Garry, regarding your "tip" below. I tried it this morning,
                        and it worked like a charm! Thanks.
                        quote Garry in Tampa:
