Home › Forum › Ask A Member › QD16 Restoration
- This topic has 33 replies, 5 voices, and was last updated 3 years ago by
Steve D.
October 20, 2023 at 9:00 pm #281898
Got a case of good news bad news going on tonight.
The good news is the carbon seal on the motor was the updated version. The bad news is as soon as I started to gently twist it she gave up the ghost☹️.The new one is en route so I am hoping this will be the last piece then re-assembly can begin.
1954 Evinrude 7.5 HP
1954 Evinrude 15 HP
1954 Gale 12 HP
1955 Johnson 10 HP
1956 Johnson 10 HP
1956 Gale 12 HP
1956 Evinrude 5.5 HP
1957 Johnson Golden Javelin 35
1958 Johnson 7.5
1960 Evinrude 18 HP
1973 Johnson 6 HPOctober 27, 2023 at 9:47 am #282097Well I finally got this in the test tank last night and great news, she started 2nd pull. I had to kill it right away as there was only mist out the blubber hole☹️.
I tested pump rebuild on lower unit prior to installing and blew upper leg cooling out with air prior to installing. I did get some air through. Any thoughts? Should I just keep blowing air through or are there any other tricks?
1954 Evinrude 15 HP
1954 Gale 12 HP
1955 Johnson 10 HP
1956 Johnson 10 HP
1956 Gale 12 HP
1958 Johnson 7.5
1960 Evinrude 18 HP
1973 Johnson 6 HPOctober 27, 2023 at 10:11 am #282098Is the water level high enough in the tank? The water level really needs to be above the gearcase/exhaust hsg joint
October 27, 2023 at 10:32 am #282100Fleetwin thanks for the reply. I use a garbage can full up to bottom of the lower mounts so hopefully that was not the issue.
1954 Evinrude 15 HP
1954 Gale 12 HP
1955 Johnson 10 HP
1956 Johnson 10 HP
1956 Gale 12 HP
1958 Johnson 7.5
1960 Evinrude 18 HP
1973 Johnson 6 HPOctober 27, 2023 at 11:43 am #282103I discovered the issue the water tube missed the upper grommet. I struggled to get everything lined up but did and it pumps great! We have snow in forecast so glad to resolve this issue before winter set in!
1954 Evinrude 15 HP
1954 Gale 12 HP
1955 Johnson 10 HP
1956 Johnson 10 HP
1956 Gale 12 HP
1958 Johnson 7.5
1960 Evinrude 18 HP
1973 Johnson 6 HPOctober 30, 2023 at 8:30 pm #282160Cool! This is one of my favorite engines. I refurbished one for a friend, wish I could have kept it for myself. One of the nicest running engines ever built.
October 30, 2023 at 11:37 pm #282172fuel supply going to the air pressure nipple ???? optical illusion ?
October 31, 2023 at 3:38 pm #282182Fleetwin, thanks I can’t wait to get it on a boat next season! She sounds good and I think she will be a strong runner when I get it dialed in. Unfortunately, the snow showed up today so think my boating is done for this year.
Crosbyman, not an optical illusion, I’m afraid I’m not a purist in that I convert my oldies to fuel pumps.
1954 Evinrude 15 HP
1954 Gale 12 HP
1955 Johnson 10 HP
1956 Johnson 10 HP
1956 Gale 12 HP
1958 Johnson 7.5
1960 Evinrude 18 HP
1973 Johnson 6 HPNovember 1, 2023 at 12:10 am #282189still don’t understand why you would connect a fuel line to an air nipple ???? must be fog… pleaseexplain
November 1, 2023 at 1:13 am #282191The pulsating air is what drives the fuel pump
