Home › Forum › Ask A Member › QD16 Restoration
Viewing 10 posts - 1 through 10 (of 34 total)
  • #281735
    Jeff Barsch
      It’s been a while since I posted.  Life has pulled me away from outboards for a while.
      I am restoring a rough QD-16 that was going to Scrap so I grabbed it for $20.  It appears to haven taken a fall at one point as both recoil mounting brackets are broken and the recoil was gone.  All other parts were there.
      I have since found a port side bracket and have a WTB posted for the Starboard Bracket and recoil.
      My question is does the QD16 happen to be unique recoil or will a 1955 5.5/7.5 or 18/20/25 recoil bolt up?  I have found postings for those recoils but none for a 10 hp.
      Any insight is appreciated!
      Jeff
      ps I will post photos soon!
      1954 Evinrude 7.5 HP
      1954 Evinrude 15 HP
      1954 Gale 12 HP
      1955 Johnson 10 HP
      1956 Johnson 10 HP
      1956 Gale 12 HP
      1956 Evinrude 5.5 HP
      1957 Johnson Golden Javelin 35
      1958 Johnson 7.5
      1960 Evinrude 18 HP
      1973 Johnson 6 HP
      #281736
        sorry … monday  cloudiness…  fogg possibly     what is    recoil mounting brackets are broken and the recoil was gone??
        are we talking  pull starter recoil
        did you check compression #s and  GC condition before  venturing into the money pit ?
        #281739
        Jeff Barsch
          Crosbyman,
          sorry for the confusion!  You are correct I am looking for a pull starter recoil and the right side pull starter mounting bracket.
          Before deciding to source parts I checked and the compression was good on both cylinders, I don’t have a gauge but it blew my thumb off both holes.  I also stuck pencil in both cylinders and no rod knock and pulled the bypass covers and no visible scoring.   Lower unit oil had no water and held 5 lbs air. Carb cleaned up nicely.  I believe she will be a runner.
          Planning to do usual ignition rebuild, fuel lines, impeller.
          Thanks!
          Jeff
          1954 Evinrude 15 HP
          1954 Gale 12 HP
          1955 Johnson 10 HP
          1956 Johnson 10 HP
          1956 Gale 12 HP
          1958 Johnson 7.5
          1960 Evinrude 18 HP
          1973 Johnson 6 HP
          #281749
            if you don’t have your copy of the johnson/evinrude bible  to service oldies  of the late 40s to mid 60s  here is a site to download.  We had it here for members of aomci but the file access has been blocked.
            https://watercraftmanuals.com/outboard/johnson/manuals/johnson-302231.htm
            #281755
            Jeff Barsch
              Thank you for the link.  I have a copy of the Bible printed along with a copy of the owners and parts manual.  Now all I need is a couple of parts😉
              Attached are a couple of pictures.
              1954 Evinrude 15 HP
              1954 Gale 12 HP
              1955 Johnson 10 HP
              1956 Johnson 10 HP
              1956 Gale 12 HP
              1958 Johnson 7.5
              1960 Evinrude 18 HP
              1973 Johnson 6 HP
              #281761
              Steve D
                That’s a great save from the scrap pile Jeff. One of my favorite motors. The cover on that one looks great.
                The recoils from 5.5, 7.5, or 18/20/25 will not work. I think only 1949-1955 QD recoil will work. And the mounting brackets might be one year only. Email me at the address in the picture.
                recoil-and-bracket
                #281763
                  here is a  75U$ CD-11  I picked up 2 years ago… a real granpa’s motor  a real look-a-like of the big brother
                  #281770
                    Like Steve says, those parts are fairly unique, later model stuff will not fit.  The 1955 10hps were unique in a few different ways from later models.
                    Nonetheless, this is one of my all time favorites as well.   I’m sure you will find the pieces you need eventually, this engine is worth the effort.  Hoping Steve can help you with the needed pieces.
                    #281779
                    Jeff Barsch
                      Thanks for the replies everyone!  Crosbyman that is a fine looking motor.  Was the paint in that good of condition when you purchased it?
                      I am going to purchase those parts from Steve and appreciate being able to locate the parts so I will have a complete engine.  1955 must have been a transition year as usually there is a lot of parts overlap.
                      My coils should be in this week so hopefully I can barrel test it by starting it with the  rope and the flywheel method this weekend.
                      I do have one more quick question, looking at the parts diagram it appears the top crankcase seal is a carbon seal with an o ring.  If that is leaking is the only way to replace the o ring by splitting the case or can that seal be worked up the crank?
                      Thanks,
                      Jeff
                      1954 Evinrude 15 HP
                      1954 Gale 12 HP
                      1955 Johnson 10 HP
                      1956 Johnson 10 HP
                      1956 Gale 12 HP
                      1958 Johnson 7.5
                      1960 Evinrude 18 HP
                      1973 Johnson 6 HP
                      #281780
                        well.. wait and see on the seal… DON’T FIX IT IF IT WORKS they say 🙂
                        on my nice cd11… yes the paint is original …:-)
