Home › Forum › Ask A Member › Need recommendation for 7.5hp project
Viewing 10 posts - 21 through 30 (of 38 total)
  • #31986
      Don’t forget a Firestone, Shift, remote tank with pump, short shaft, lighter than most recoil start & twist grip throttle & fully jeweled motor, full bearings except wrist pins. I have enjoyed mine for over 30 years now. Doesn’t get used every time but it gets out often.
      #31987
        Don’t forget a Firestone 7.5 1953, Remote tank, one impeller, full shift, tiller throttle, lightweight fully jeweled except wrist pins, small gearcase to slide thru the water, same gears as the 10hp very reliable when tuned up correctly, rewind starter, shear pin & full driveshaft, nothing to break,give it a try!
        #31988
          Then might try a Mercury motor too, A little heavy except the super 10 KH7 but no remote tank Very fast for a 10hp
          #31992
          Leon
            Hey Mumbles, I actually have a 7.5hp Hiawatha outboard that was built from the Scott that you have. 🙂
            #31996
              Don’t forget the McCulloch built Ted Williams low profile motors for hours of entertainment or the Gamefisher 7.5 horse motors!
              Doug Wilson
                1959 was the last year the pressure tanks were used on the smaller fishing motors. 1960 all of the motors used
                the single line tanks.
                Doug
                Doug
                turned off?
                #32018
                jpatti75
                  I’m going to throw in another option to consider….a West Bend made Elgin from 1955 to 1959. They had 5, 7.5, and 12 HP full gear shift models with fuel pumps, as well as one 12HP that could be locked down at the lower HPs for HP-restricted waterways. I had a 12HP model, and what a reliable and great running motor. They’re a little less common than the many little green Elgins out there with the integrated fuel tank, but it shouldn’t be too hard to track down. I think they are an under appreciated motor … probably because they are a little homely compared to the beautiful OMCs of the same time period.
                  #32023
                  Leon
                    Kinda like an old Rambler station wagon. Unpopular as sin, but runs till the end of time. There is a lot to be said, for this situation, and those in the right mind will appreciate it. It kinda helps deter the thieves too. 😀 😀
                    #32025
                    chinewalker
                      One often overlooked reason to leave your old 5.5 or 7.5 Johnrude as a pressure feed motor is that you’ll never accidentally mix up your tanks and accidentally run your plain bearing motor on a 50:1 mix!
                      #32026
                      jerry-ahrens
                        I’ll second what jpatti sayes on the West Bend motors. Excellent running and very powerful. I was recently at club member Mark Trimbles meet and ran across this 25 hp green Elgin, with factory electric start. Kind of a neat motor.
