Home › Forum › Ask A Member › Need recommendation for 7.5hp project
Viewing 10 posts - 1 through 10 (of 38 total)
  • #3637
    ronboonville
      I am not familiar with Johnson or Evinrude outboard models. So help me figure out what model I want, twist throttle, 7.5 hp, not a pressurized tank I have single line tanks. a built in tank would be ok, FNR a must. I like the looks of the fleet twin but am open to a Johnson. Let me know your opinions, thanks! something from the 50’s. short shaft.
      #31923
        It would have to be a pressurized tank then, unless you simply put a fuel pump on it, which is very easy to do.
        #31924
        wedgie
          Here is a 1957 Fleetwin that I just got running today. I too like the Evinrude styling of this era. The only drawback for you is that it needs the pressure tank to run. However, It could be converted to run off of a single line non pressure tank by the addition of a fuel pump and a little modification of the plumbing 😉 .
          If you wanted a 7.5 with built in fuel tank you will have to go for an earlier version of the Fleetwin.
          #31926
            And here is a ’55 which falls between the years Wedgie posted
            #31929
            ronboonville
              okay, looks like the fleetwin is what I need. I can deal with the fuel pump, like my sea king 5. So what would be the Johnson counterpart? Also is one better?
              #31930
              wedgie
                The 7.5 hp Johnson version is an AD . Just cosmetic differences .
                #31931
                wedgie
                    If you want a newer Johnson 7.5, here’s one from the early eighties. FNR, fuel pump, short shaft.
                    Since it’s 30+ years old now, we can call it ‘vintage’ with a straight face! 😀
                    slim60
                      If you go with a fifties Evinrude, in fifty six the recoil was changed making it easier to pull.
                      #31942
                        So, what year was it that Johnson and/or Evinrude went to fuel pumps?
                        Kirk
