Home › Forum › Ask A Member › Mercury Mark 5
Viewing 10 posts - 21 through 30 (of 46 total)
  • #52030
    cheetahgod
      Is there anything I should do carefully when removing the lower unit?
      #52032
        disconnect the shift cable then the 2 nuts and it will come right down. going back up is a different story. call me when you get that far. 1 914 310 7086.
        #52038
        cheetahgod
          ok thanks.
          #52052
          cheetahgod
            I’ve gotten the lower unit off the mark 5. How do I disconnect the bottom gear housing off the upper part? It seems there is a large spring preventing the two parts from separating.
            #52070
              Phillips up in the exhaust snout.
              #52072
              cheetahgod
                I took that screw off already.
                cheetahgod
                  I took that screw off already but the spring is still attached
                  #52074
                    turn the drive shaft backwards to loosen the spring but hold the prop shaft .
                    #52075
                    cheetahgod
                      THANKS. It worked
                      #52077
                      cheetahgod
                        How do I get the rest of it apart ?
