Home › Forum › Ask A Member › Mercury Mark 5
Viewing 10 posts - 1 through 10 (of 46 total)
  • #6193
    cheetahgod
      Bought my first vintage outboard. Yay! What do I need to do in order to get this motor running? The motor turns over. I plan on checking the compression when I buy a tester. How do I get to the spark plug?
      green-thumbs
        Welcome to the hobby.
        Spark Plug access by removing cowl which is retained by non removable
        1/4 turn spring loaded Duzus fasteners. It is common for long stored outboard
        to have no or weak spark. Sometimes cleaning/polishing points is all that is
        needed. What it will take to restore an old outboard to good running condition
        will depend upon prior use and care. Assume nothing check everything.
        Do not be afraid of grease and grime the preservatives of old outboards.
        Louis
        #51762
        cheetahgod
          thanks
          #51763
          cheetahgod
            what is the best place to get parts and a manual
            for this motor?
            #51766
              Email oldoutboardjim@hotmail.com about coils and condensers.
              These guys have parts
              http://www.vintageoutboard.com/
              http://www.fergusonpoolemarine.com/outb … parts.html
              cheetahgod
                The guy who I bought the motor from said it was his dads. They had it on a wood boat and backed the boat into a tree causing the boat to disintegrate. The motor has been in storage for 30 years
                #51773
                cheetahgod
                  Power head
                  ROBERT LAFAYETTE
                    Check out Art DeKalb’s 5 point plan for getting the Old Iron running again.
                    http://precisionservoutboard.com/about/ … oint-plan/
                    Thanks for the great tips ART.
                    cheetahgod
                      What is a good compression range for this outboard ?
                      #51794
                        120 but even is what to look for . let us know. gauges can read different.
