Home › Forum › Ask A Member › Mercury KD4
Viewing 10 posts - 61 through 70 (of 140 total)
  • #229161
      second hole is for the shear pin and prop without he clutch hub. just the prop look in the prop and you will see the cut out for the shear pin.
      #229190
        The clutch gets driven by the same pin that drives the impeller. The second hole in the shaft, seen in your picture, is not used when there is a clutch. That hole would be for a shear pin to drive on the propeller directly, with no clutch.
        #229196
        ROBERT LAFAYETTE
          Chart14-1
          Chart8
          #229199
          Boonie
            Yup thanks. All makes sense now. Now I’m looking to replace the seal in the pump housing. How in the heck does one get that out?
            #229200
              Bill the clutch is not driven by the impeller pin the 2 holes are outside the pump.. one for the clutch and one for prop without clutch as I have said ..
              #229244
              Boonie
                Any tips on seal removal?
                #229247
                  tap it out from behind with a hammer and screwdriver.
                  #229248
                  Boonie
                    And if you can’t get on it from the back? Brass bushing in the way.
                    #229269
                    green-thumbs
                      Removing the old seal is not a neat and tidy affair for me. I use hammer and punch to beat in the rim of seal so I can grab on it with nippers and bite off pieces. There probably is a neat and clean method other have discovered, but. not shared. Not a difficult job, just time consuming.
                      The real problem is that the old hard seal has worn a groove in the prop
                      shaft so a new seal will not work or last.
                      Louis
                      It seems to me the lower unit illustration is for later type lower unit
                      not KD4 type.
                      #229293
                      kirkp
                        lower-unit
