Home › Forum › Ask A Member › Mercury KD4
- This topic has 139 replies, 16 voices, and was last updated 5 years, 6 months ago by
Boonie.
April 6, 2021 at 8:36 am #235744
So it looks like you had enough play/room to get 2 nuts and a washer between the cylinder and the case? Or did get that one off using another technique?
This reply was modified 5 years, 7 months ago by
opposedtwin.
April 6, 2021 at 7:41 pm #235797Well I had to throw everything at this one. First I filled the cylinders up with WD40 for a couple days. Nothing moving. Soaked for another week. Nothing. Then I tried liquid wrench for a couple days. Nothing. Then I tried some evapo rust. That stuff does a number on rust but still no movement. So I took it to work and preheated the oven to 350 degrees and put the power head in for about a half hour, then moved it to our walk in freezer. Then soaked it overnight in WD40. Next day put the flywheel on and using a strap I had a friend put as much pressure on it as possible. I took a wooden dowel and put it in the spark plug hole and with some heat gave it a whack. Pop, the top piston came free. Have been soaking the bottom piston and tomorrow will try the heat , freeze method again
April 6, 2021 at 11:29 pm #235874Nice!! Thanks for sharing! Have always been curious about the oven method. Next time my wife’s out of town I may give it a try!
ScottApril 7, 2021 at 3:28 pm #235897Go to M.G. Chemicals & buy “Super corona dope” It is a very high voltage liquid insulating covering. If you want to stabalize the coil use fibergalss cloth, the very thin cloth used for radio controled toy airplanes from a hobby shop. cut to size & saturate the cloth using corona dope. It looks like clear fingernail polish.
April 10, 2021 at 11:30 am #236030Hallelujah. Free at last. I learned one thing for sure. I have more patience than my wife says I have!
April 10, 2021 at 11:40 am #236032One question I have. Do I have to remove the crankshaft to replace the seal on the flywheel end? Bottom end has a cap that comes off.
April 10, 2021 at 8:11 pm #236122I beieve you do. Kirk p has a thread in the “projects column” where he discusses these seals. I believe it’s entitled “WB3”.
https://www.aomci.org/forums/topic/wb3/
opposedtwin.
April 11, 2021 at 2:47 pm #236163Several things I would want to know if it was on my agenda.
1) are rods rusted to crankshaft
2) are both pistons stuck
3) signs of prior attempts to unstickI have had good results with Marvel Mystery Oil on very lightly stuck
powerhed. If both pistons are stuck and or rod bearings rusted to
crankshaft. freeing up and disassemby may be difficult,I would apply oil thru spark plug opening, exhaust ports and thru crankcase opeing to cylinders. The stuff oiled paper in thru spark plug opening to reduce volume of grease required. Next attach grease gun to spark plug adapter and attempt to free piston that is hight in cylinder,
Do not overdo it! Exhaust ports can be blanked off to seal grease in
If you can move piston down far enough to gain work space between
cylinder and crankcase for nuts and threade rods you can pull the
piston completely clear of cylinder. The piston often will require this
to mover it the last inch or two our to cylinder.
Both grease gun and nuts, washers and threaded rods are powerful
tools that will free up most stuck pistons and ALSO break things if nothing wants to give.I once pickup up a stuck KE4 powerhead that someone had tried to freeup with a pipe wrench. Did not work and lefte deep indentations
on crankshaft taper. It responded to greasegun methods with very
little pressure. needed.Sometimes you can remove unstuck cylinder and piston & rod assembly and gain enough space between the stuck cylinder and crankcase
to use nuts, washers threaded rods to pull the piston out. Depends
on where piston is in the cylinder.
If low a go, If high grease gun.
LouisApril 11, 2021 at 8:57 pm #236189Ok so pistons are free, next step is to free up the rings. Is it possible to buy new pistons and rings? Also I need new seals for both ends of the crank.
April 12, 2021 at 1:52 pm #236217Does anyone know how to remove the crankshaft from this Kd4?
