Home › Forum › Ask A Member › Mercury KD4
Viewing 10 posts - 41 through 50 (of 140 total)
  • #227303
      those filters have a thread on the bottom that screw into a bridge in the fitting. very thin . it looks like the threads have broken off in the first pics.
      #227364
      Boonie
        Need a part # for a water pump impeller for this Kd4?
        #227382
          This is what I have in my notes…….
          18-3072 Sierra impeller for Mercury KD4
          Overall Diameter : 48mm 1.89
          Shaft Size Diameter : 11mm .433
          Depth :13.5mm .531
          Blade :6
            In looking at my photos on my KD4, it appears I used parts from two different KD’s, one had a wobbler pump,
            but I ended up using the Sierra impeller somehow!
            Also looks like I make my own impeller drive bushing last winter. Don’t believe I ever got around to running
            it to see if it worked.
            Other’s have done the retrofit “different than I, so hopefully someone will say how.
            DSCN8599
            kirkp
              The part number for the vane impeller is M-50-137. Couldn’t find where you have said what your serial number is. According to the info I have, depending on the number you could have a oscillator style impeller. On the first page of your post fifty2One posted pictures with all the part numbers you’ll need.
              Kirk
              #227496
              Boonie
                Recommended place to find decals for this motor?
                #227503
                  https://discontinueddecals.com/store/c/34-Mercury-Decals.aspx
                  is where I got mine.
                  ROBERT LAFAYETTE
                    I get all mine from Tom Thuerwachter he has many parts for the old “K” series MERCURY’s
                    TOMT
                    #227565
                      Winnebagolandchapterland.com takes me to some Chinese site advertising
                      casino’s, and perhaps more!
                      Boonie
                        Thanks Guys.
                        Picked up a new to me motor today. 1956 Johnson Javalin, RJE-18. Good compression and spark on both cylinders. Price was right. Free! Electric start but starter missing. 30 hp. Hard to pull with a rope.
