Home › Forum › Ask A Member › Mercury aluminum prop
  • #65298
    wedgie
      If you have access to a sand blast cabinet, a quick once over will give the aluminum a nice profile for the primer/paint to grab hold of.
      The blast cabinet I have access to at work is a pretty powerful one, so I take care not to linger in any one spot.The heat generated could warp the blades and/or thin them out along the edges.
      Once blasted, I coat with epoxy primer and a urethane top coat. you are unlikely to have these coatings on hand so just use an etching primer with a rattle can for finish, then touch it up whenever it looks in need.
      #65320
      captchuck
        Never heard the word ‘penurious’ before. Not to hijack this post but what does it mean? When I tried looking it up the definition I got did not fit your sentence. Being an old man I must have missed it in school some 50 years ago.
        #65327
        wedgie
          quote CaptChuck:
          probably an auto correct error 😉
          #65329
            This is what I found – – – 😕
            #65335
            wedgie
              I’m guessing Tubs meant to type "porous"
              #65338
                Nope, I’m penurious.
                Its why my hobby is antique outboards.
                There all I can afford. 😉
                #65359
                fisherman6
                  Here is a Michigan PJ-18 I polished up. It was really crusty and pretty beat up when I got the prop. I sanded with my orbital palm sander and 120 grit, hand sanded with 220 grit, and hand polished with White Diamond. It will get dull after running it a bit, and you do have to keep up on it to keep it shiny. It does look nice when it’s polished though.
                  -Ben
                  OldJohnnyRude on YouTube
                  #65360
                    Looks good But I would use a washer under the nut before you loose it.
                    #65361
                    fisherman6
                      Ya, that’s a good idea Dave. It can’t go anywhere unless the hub let’s go, but if that happened it could possibly slip off there in reverse or slowing down. I usually use the regular cone type prop nuts which eliminates that problem.
                      -Ben
