Home › Forum › Ask A Member › Mercury aluminum prop
  • #8297
    cheetahgod
      What is the best way to polish and prevent oxidation of aluminum prop?
      #65261
      WAYNE
        It’s a losing battle. Wax seems to help a bit.
        Wayne
        Upper Canada Chapter
        uccaomci.com
        #65262
          The polish itself protects the metal but
          it has a limited time that it is effective
          depending on exposure. It can last for
          years in a controlled environment an
          only weeks say on the wheels of a car
          that is driven every day. A prop that
          is left in the water is a matter of days.
          Anything you put on the polished
          surface to protect it will take away
          some of the shine. (waxing or clear
          coating) So to maintain the maximum
          shine you polish when it looks like it
          needs to be polished. Polished
          aluminum requires some maintenance.
          Its why people chrome it.
          #65263
          jpatti75
            As a polish, White Diamond is pretty good (although Mothers is one of my favorites), although as a sealant to slow oxidation, White Diamond is especially good. It’s pricey, but a little goes a long way.
            https://whitediamondamerica.com/product … nd-sealant
            JP
            #65266
            cheetahgod
              Ok. I think I might paint it red. What would be the best way to paint it?
              Thanks
              #65278
                Use a self etching primer.
                Or you could bring the price of the polish down by getting 5 others to go in on a case with you. . . 😀
                #65289
                jerry-ahrens
                  I like Flitz polish. Great stuff for aluminum, and most metals. It also works great for fiberglass and painted surfaces including clear coat. I keep a bottle on the work bench at all times. Like Tubs said, you have to give a buffing once in a while to keep it shiny. http://www.flitz.com/
                  #65291
                    If your going to paint it first you will have to get it
                    clean. Its been exposed to oil and aluminum is
                    somewhat penurious. One of these water based
                    grease removers is probably the best choice.
                    Let it soak in a 50/50 mix for awhile then rinse
                    it off well. The metal etching primer that Garry
                    mentioned is a necessity if you want the paint to
                    stick for any amount of time. You should understand
                    that the paint on a spinning prop is being exposed
                    to roughly the same strain as if it was being sprayed
                    with a high pressure washer. Any fracture or week
                    point will lead to the paint pealing off epically at
                    the outer edges of the prop. When I paint a prop
                    I use a metallic (silver – gold – copper). No
                    primer. I just clean it well and spray it on. The
                    metallic’s touch up well and with out the primer
                    you can easily strip the paint off (lacquer thinner) and
                    redo it for a show or just to hang on the wall till
                    spring.
                    #65293
                      Tubs,
                      Nice Merc prop & the KE7.
                      #65296
                      20mercman
                        I have had some props that refuse to hold on to paint, and others that I have painted and the have many miles on them and no issues. I think that the ones I have that are resistant are ones that had spent a lot of time with no paint on it, and they absorbed oil into the metal. The hubs are one section that I have on 1 prop that sheds paint like a wet dog.
                        P.S. I paint some of mine gold like you did on that KF-7 prop. This color seems to have better tooth than my cloud white on my Mercury’s.
                        Steve
