Home › Forum › Ask A Member › Magneto Cam and Timming Tool Question
Viewing 10 posts - 41 through 50 (of 50 total)
  • #303517
      Did not see  that critter… odd looking  thing
      #304460
      olcah
        Hey Kent,
        It has been awhile, where are you at with this project?
        #305167
        Kent Cochran
          Quick update on the 1952 10 hp johnson QD-13, I  have gotten my carburetor parts and leaf plate gaskets in to continue with this project. Details to come. I got side tracked on this project.
          I have been working  on a coworkers 1956 7.5 Evinrude, he had it hanging in his Man Cave, I volunteered to get it running and give it complete tune up. It had a blown head gasket. No compression on bottom cylinder. It is up and running now. I will be installing the new updated water pump  tomorrow and this job will be completed.
          Kent
          Kent Cochran
          1949 10 hp Johnson QD-10
          1951 5 hp Johnson TN-27
          1952 10 hp Johnson QD-13
          1956 7.5 hp Evinrude 7520
          1957 7.5 hp Evinrude 7522
          #310994
          Kent Cochran
            All,
            I have good news on my 1952 10 hp Johnson QD-13.
            She is FINALLY RUNNING!!!
            I sure do appreciate every one’s advice. It was fuel problem whole time. I cleaned the Reed Plate and replaced both gaskets with new ones. After changing lower unit oil. She fired up on the third pull. I was shocked that she was pumping water. See attached photos.
            Thanks for everyone’s troubleshooting tips, Kent
            Kent Cochran
            #310997
            Kent Cochran
              Kent Cochran
              #311026
                Great news…  feed it lots of oil  and it should last years and years .  Some folks  change gear oil mid season if water seeps in…
                GC oil is cheap  and a rebuld takes practice.
                thanks for your feedback
                #311156
                Kent Cochran
                  https://youtube.com/shorts/xfcWqjUBxBw?feature=share
                  Kent Cochran
                  #311164
                  Kent Cochran
                    https://youtube.com/shorts/uf8PtrfYAaY?feature=share
                    Kent Cochran
                    #311180
                      Sounds great! I like the stand too with the little stock tank.
                          Sounds like its Boat Ready!!!.
