Home › Forum › Ask A Member › Magneto Cam and Timming Tool Question
Viewing 10 posts - 31 through 40 (of 50 total)
  • #303388
      I frequently  just  paste pictures in Powerpoint  & shrink them down a bit not to exceed 2 meg and give them a file name.
      I fetch the  the file  & attech them to my posts.
      did you read the manual on those older carbs
      #303396
      Kent Cochran
        Yes I have read the manual on this Carb. Do you think there is something I have over looked? I can sure reed it again.
        There is no rebuild kit for this carb. You can bay some of the parts individually.
        Kent Cochran
        1949 10 hp Johnson QD-10
        1951 5 hp Johnson TN-27
        1952 10 hp Johnson QD-13
        1956 7.5 hp Evinrude 7520
        1957 7.5 hp Evinrude 7522
        #303415
          can’t say from here … one option is lack of  adequte suction on the carb  if some crank seals are allowing the upstroke vacum to be replenish by “outside ” air   instead of a good fuel air mix pulled in from    the carb itself . I have no parts diagram to explore but see video
          which may offer  a solution.
          https://youtu.be/f3O_dqvCDIU
          #303440
          Sam M.
            if I over prime the Carb. itself it will leak foul from throat of the Carb.
            I think your carburetor is different than the one Johnson equiped their 10hp motors with in 1953, but maybe it is similar enough for the following to apply.
            On my 1953 Johnson Model QD-14, after priming with the primer on the pressure tank, when I prime the motor’s carburetor by pushing in on its portside knob, fuel gets propelled into the carburetor “throat” but will leak out the front if the motor is trimmed too high.  I find that by tilting the motor back so that the primed fuel will flow towards the crankcase and not out the front, I can get the motor to start.  If you’re using a test tank and stand setup that are not connected, then just put some bricks or wood blocks under the front of the stand to tilt it if you want to leave the motor’s tilt adjustment set for optimal display on a stand.  Just be careful of the balence.  Hope this helps!
            P.S.  I can see several photos you posted, just not in your post that said
            Here are a few photos of the carburetor my motor has if this helps.
            #303450
              over priming leaks  are likely poor carb float shut off problems which basicaly work just like toilet bowls.  When full no more water  flows in “reservoir”  same thing with carbs !
              Some leaking when tilted up  may simply leaking out the carb’s  open  air vent used for atmospheric balance. As the carb fuel gets sucked in the engine the vent prevents vacum build up in the carb. This “vent” concept may or may not apply to pressure tank systems but check anyway where exactly the leak originates.
              In any event openning the tank cap will drop the built-up pressure  on the fuel distribution.
              #303493
              Kent Cochran
                I went ahead a pulled the carburetor off again for inspection.
                I do not see any issues with the carburetor itself. During my inspection I did notice the outer Leaf plate gasket that attaches to the carburetor side was cut in one spot. I will have to order a new one.
                Should I have taken the leaf plate apart for cleaning, or was this a bad idea? Should I also replace the rubber check valve that is on the leaf plate? Any advice on how to clean the leafs themselves?
                I  am going to try to post some more photos of the carburetor.
                Thanks, everyone for your advice. This one has been challenging so far!
                IMG_4434IMG_4436
                IMG_4459
                IMG_4455
                Kent Cochran
                #303498
                Kent Cochran
                  Couple of more photos. I think I have got the attaching photos down!!!
                  IMG_4454
                  IMG_4457
                  Kent Cochran
                  #303513
                    from here that glass bowl filter looks pretty bad… why not take it out for a test run
                    you could always hook up a lawnmower filter  on the fuel line instead  and leave the bowl filter out.
                    #303514
                    Kent Cochran
                      Check out the photo with little green bowl. I have built a hose (yellow) with a new inline filter. I will leave the main filter out, when I reassemble and install the carburetor.
                      Thanks, again for your help.
                      Kent Cochran
                      #303515
                      GARY
                        Replace the crank seals.
