Home › Forum › Ask A Member › Johnson rotary valve bearings
  • #47428
    George Emmanuel
      Randy,
      Sealed bearings are not shielded bearings!—Two different items.
      And David Bartlett, the fuel mixture does not pass through those bearings. Originally they were greased.The bottom one has a felt wick and condensation created when running has a tendency to settle in the bottom bearing, which is not good long term.
      I suggest and use sealed bearings.
      George
      #47444
      dmbono
        I did buy sealed bearings. They probably didn’t have reliable seals in 1929.
        #47452
        Randy in Tampa
          quote George Emmanuel:
          Randy,
          George
          Thanks for correction on terminology George 😉
