Home › Forum › Ask A Member › Johnson rotary valve bearings
  • #5664
    dmbono
      Working on an S-45 Johnson, and just pulled the rotary valve apart. The bearings need replacing, and were open radial ball. I can buy shielded or sealed bearings- any reason not to use them?
      #47228
        I don’t know much about bearings, but know I was able to "pop"
        out the shield on a bearing where one wasn’t used.
        I can’t remember the brand nor the application, but it
        might be an option.
        PM T2
          Dave I suggest that you contact Jay Walls about your rotary valve bearing question.
          Best,
          PM T2
          #47232
            I have also removed seals from bearings
            to be used where an open bearing is
            required. Was the recommendation of
            a bearing supplier some 50+ years ago
            and seams to be a reoccurring solution
            over the years.
            #47238
            amuller
              Yes, you can pop the shields or seals and use them as open bearings.
              #47242
              dmbono
                I worded the question badly- Can I use shielded bearings instead of open?
                #47246
                david-bartlett
                  quote dmbono:
                  I guess you could. The original open bearing would have been lubricated from the fuel mix going through then engine, which is pretty foolproof if one adds the correct fuel/oil mix to the motor.
                  A sealed bearing will not benefit from this obviously, and would work fine until the original lubricant inside the seal/shield gets use up, worn out, or contaminated. You probably won’t use the motor enough to do this.
                  Just my $.02
                  If it were me, I would go with open ball bearings.
                  #47248
                  TOM GOEPFRICH
                    I’ve used the sealed bearings (not shielded) in my V65 and P65. I think they’re better than the open ones and have had no problem in 10 years or so of light use.
                    #47254
                    dmbono
                      Thank you all for your response! I’m installing shielded bearings
                      #47342
                      Randy in Tampa
                        ditto go with the sealed bearings make sure they’re all metal
                        quote eltoquad:
