Home › Forum › Ask A Member › Johnson 10 power head upgrade?
- This topic has 28 replies, 13 voices, and was last updated 10 years, 4 months ago by
Steve D.
July 1, 2016 at 1:51 pm #39357quote ShoestringMariner:Guys, I know this is an old thread, but will this upgrade work on a 1954 10hp powerhead?
Sure will Scott. Not hard to do, especially if you are going to open up the powerhead anyways. Not a cheap conversion though, if you have to hand buy/pick each part.
July 1, 2016 at 2:45 pm #39361quote Chris_P:quote ShoestringMariner:Guys, I know this is an old thread, but will this upgrade work on a 1954 10hp powerhead?Sure will Scott. Not hard to do, especially if you are going to open up the powerhead anyways. Not a cheap conversion though, if you have to hand buy/pick each part.
Thanks Chris. I know my user name implies I’m rather frugal, which is true however I don’t mind spending good money on something that’s worth it in the long run. Of course I haven’t priced out all the parts yet LOL
July 1, 2016 at 4:26 pm #39368If you go that route, there are a few great guys on here that can sell NOS parts at reasonable prices. Place a wanted ad in the webvertize and they should be able to help you out. I don’t have any rods or bearings left myself.
July 1, 2016 at 5:08 pm #39375quote Chris_P:If you go that route, there are a few great guys on here that can sell NOS parts at reasonable prices. Place a wanted ad in the webvertize and they should be able to help you out. I don’t have any rods or bearings left myself.Excellent, thanks Chris.
July 1, 2016 at 6:46 pm #39384July 1, 2016 at 10:59 pm #39405I don’t know what happened but somehow I deleted my original post.
image hostingJuly 2, 2016 at 7:13 pm #39476Just an added thought to the roller bearing models. Did the later Gale built 10’s get roller bearings, if so what years?
Thanks
July 2, 2016 at 7:13 pm #39477Just an added thought to the roller bearing models. Did the later Gale built 10’s get roller bearings, if so what years?
Thanks
July 5, 2016 at 7:48 pm #39644I’ve been working on getting a ’61 Evinrude 10 HP on a ’56 15 HP lower unit. Lots of mix ‘n match but so far so good running in the driveway. Removed the original manifold/reed plate and installed an earlier one so I could use a dual hose tank. New cylinder head gasket, manifold gaskets, base gaskets, and exhaust cover gaskets, flywheel and recoil from ’56-’57 10 horse, swapped out carb needles to accommodate the cover, knobs, etc. A lot of different colors but at least it’s all blue. Have to get it in the water and try it out on the boat next.
https://www.flickr.com/photos/55515333@ … res/Q4kEY0
how to capture screen
hosting images
screen shot pc
screen shot pc
screen shot pc
screen shot pc
screen shot pc -
