Home › Forum › Ask A Member › Johnson 10 power head upgrade?
Viewing 10 posts - 11 through 20 (of 29 total)
  • #18903
    enrico-italy
      I tried to made a 1960 "frankietwin" mixing a ’60 FD leg/gearcase with a ’60 QD PH and cover.
      The project aborted because the lower cover front bracket of the QD cannot fit on the FD leg
      I need to swap also the front carrying handle, but I suppose the steering pivots also not fit …
      #18905
        quote 1946Zephyr:
        If you’re pushing a 14 foot boat though, stepping up to a ’57 Fastwin 18 is a better choice yet.
        Agreed! An eighteen on a fourteen foot tinner is a great combination!
        #18914
        Leon
          I actually have a "Frankentwin" 18 that I just got running last weekend. It’s a 57 Fastwin with a 58 FD lower unit on it. The paint looks like hell and it’s been rattle canned, but this motor runs great. Those old 18’s are tough as nail and handle a lot of neglect and abuse. I think I’m going to put the lower back on the FD and restore it though. Plus do the same with the Fastwin. Both of my 18’s are factory electric motors.
          #39255
          shoestringmariner
            Guys, I know this is an old thread, but will this upgrade work on a 1954 10hp powerhead?
            #39259
            mr-asa
              quote Chris_P:
              If you want to upgrade your pre ’61 10hp powerhead, order the following:
              Wrist Pin 307849 x2
              Connecting Rod 378330 x2
              Piston 378285 x2
              Needle Bearing 378251×2
              Big End Needles 378150 x2
              Piston Rings 378416 x2
              Circlips 302577 x 4
              Then if you have her apart, might as well change the carbon seal o rings
              301967 x2
              How far back does that go? Down to the QD14? the QD13? Any pre-61 10HP?
              #39333
              DAN ANDERSON
                I believe it goes all the way back to QD-10? Someone will correct me if I am wrong.
                Dan in TN
                #39340
                  QD or Sportwin stuffings.These should all fit.
                    Great picture!!! That pretty much explains it.
                    #39348
                    Leon
                      I actually have a ’55 QD in pieces now. Fortunately, I found a good rod set out of a ’53, so I won’t need these mods this time. Will keep this in mind though.
                      #39355
                        Tip: The wrist pin bore in the piston is usually worn even worse than the bushing in the rod.
