Home › Forum › Ask A Member › Johnson 10 hp
Viewing 4 posts - 21 through 24 (of 24 total)
  • #40857
      The housings are the same, only the plates differ.
      #40858
        I think you would have to change mag plate as well, but would have to verify.
        #40859
        Steve D
          The inside diameter of the top of the smaller flywheel (58-63) is approx. 6" at the widest part. If that’s what yours is all you need to do is get the parts shown below that were mentioned earlier and you’ll be all set. Your pulley looks correct and original for that flywheel.
          screen shot on pc
          image hosting 12mb
          #40923
          mgsolakis
            Yup that’s my flywheel, I just measured it. Thanks a lot I will order the parts.
