Home › Forum › Ask A Member › Johnson 10 hp
- This topic has 23 replies, 10 voices, and was last updated 10 years, 3 months ago by
mgsolakis.
July 23, 2016 at 2:52 pm #40747
Make sure to get the correct spring as they vary in length.
http://www.marineengine.com/parts/johns … rter+Group
July 23, 2016 at 3:04 pm #40752Anonymous
Mgsolakis
Here’s a link to marinengine’s parts breakdown;
http://www.marineengine.com/parts/johns … rter+GroupSteve A W
July 23, 2016 at 4:37 pm #40753July 23, 2016 at 6:51 pm #40760You need:
2x 203713 Link Connections
1x 203697 Starter Pawl Spring
1x 203698 Starter Pawl
1x 203470 Retaining RingIf no one close to you has what you need let me know. I have a large assortment of OMC parts.
July 24, 2016 at 1:16 am #40781I may have one need to check in the shed does the casting have a part number on it?
DougDoug
turned off?July 24, 2016 at 2:16 am #40787I will check.
July 24, 2016 at 12:43 pm #40808The thing to remember here is that flywheel size/diameter changed in 1958 for the 10hps. So, the location of the engagement pawl on the recoil changed as well. So, if the flywheel/recoil are mismatched, you will have an issue….The starter on the right, with the pawl closer to the hub, looks to be for the smaller diameter flywheels on the 1958 and up models. The starter on the left, with the pawl farther out from the hub, looks to be for the larger flywheels on pre 58 10hps.
July 24, 2016 at 3:11 pm #40811quote fleetwin:The thing to remember here is that flywheel size/diameter changed in 1958 for the 10hps. So, the location of the engagement pawl on the recoil changed as well. So, if the flywheel/recoil are mismatched, you will have an issue….The starter on the right, with the pawl closer to the hub, looks to be for the smaller diameter flywheels on the 1958 and up models. The starter on the left, with the pawl farther out from the hub, looks to be for the larger flywheels on pre 58 10hps.Very good to know Fleetwin ! I learn something new every day !
I assume if you swap both the flywheel and starter together everything should work out, or are there other factors involved ?
July 24, 2016 at 4:29 pm #40817quote Wedgie:quote fleetwin:The thing to remember here is that flywheel size/diameter changed in 1958 for the 10hps. So, the location of the engagement pawl on the recoil changed as well. So, if the flywheel/recoil are mismatched, you will have an issue….The starter on the right, with the pawl closer to the hub, looks to be for the smaller diameter flywheels on the 1958 and up models. The starter on the left, with the pawl farther out from the hub, looks to be for the larger flywheels on pre 58 10hps.Very good to know Fleetwin ! I learn something new every day !
Well, this is not something I figured out, was pointed out here earlier by Frank I believe. But, I’m thinking that you could use the smaller diameter flywheel on the older motors (56-57 models) with the newer recoil. And, I’m sure you could go the other way as well, put the larger diameter flywheel and older starter (56-57 models) on the newer engines (58-63). To clarify, when I say "starter", the only part that is different is the recoil pulley, I’m pretty sure the housings are the same on both styles of starter.
July 24, 2016 at 11:53 pm #40854The number on my flywheel is 377228.
