Home › Forum › Ask A Member › Fuel tank dent repair
  • #263408
    opposedtwin
      I agree with Tubbs, you done good!
      #263436
      Monte NZ
        That tank looks great Sam. You have certainly made a great job of it……..well done!
        If it’s any help to you or others, should you try filling dents on a brass tank such as the British Seagull, use an epoxy filler, not bog.
        I found this out the hard way recently, when I discovered that the bog won’t feather out nicely prior to painting, whereas the epoxy will.
        Monte NZ
        #263470
        brianlejeune
          WOW ! 15 years old, you have awesome talent .
          Brian
          1947 - 2.5 hp Sears Elgin
          1973 - 6 hp Evinrude (Fisherman)
          1981 - 9.9 Evinrude
