Home › Forum › Ask A Member › Fuel tank dent repair
  • #263284
    Sams Outboard
      Hey folks. I was curious what some of you guys do to repair a fuel tank that’s badly dented. What I’ve done is used compressed air to try and remove some of the dents. Then use body filler in thin layers to fill in the remaining dents. The photo shows the front of the tank. Though there was plenty of dents on the sides too
      #263321
      Dale
        Sam you have that tank looking good!   As for dent removal you name it somebody has probably done it.  I have had to cut a hole on the inside a couple times, bump out the dent and then get the hole in the tank welded.   I have many motors around here that I call Lumpy!  Previous owners must have thrown the old kickers around like a football.   Some members like to polish the aluminum to look like chrome.   I am too lazy for that.  Good luck with your paint.
        dale
        #263325
        Sams Outboard
          Hey there thanks for the reply! This tank was just a mess and this is the first fill restoration I’ve done. I didn’t really know if I was doing things the “traditional way” but good to hear I was on the right track. The paint color I used isn’t a perfect match but it’ll do for me. I’m using this particular project as a learning experience for future restorations on what to do and what not to do. The photo I put is what it looks like now. There’s a spot on the other side where the paint underneath the clear rippled a little. That was my own mistake. All good though
          #263328
            Much of what I can do I learned by doing it including
            removing dents from gas tanks. The tanks on the
            motors I have repaired are mostly square. Simple
            compared to your tank. Mostly curved but still flat on
            top. And then there are those straight lines. Yikes!
            That’s quite an accomplishment for your first attempt.
            You done good.
            #263331
              I have a few tanks to send you for repair!
              Compressed air can be a great aid in removing dents, but
              be aware if you try it on a rectangular tank…….. they could
              end up “round” in a hurry!
                Nice job, looks good!  If you do lots of these, you’ll find that Bondo is your friend.
                1982 Evinrude 25hp
                • This reply was modified 4 years, 3 months ago by Bob Wight.
                #263338
                brianlejeune
                  Awesome job. You must have been an auto body repair guy in your early life.
                  Brian
                  1947 - 2.5 hp Sears Elgin
                  1973 - 6 hp Evinrude (Fisherman)
                  1981 - 9.9 Evinrude
                  #263356
                  Sams Outboard
                    Hah I wish I was. I’m actually 15 this is the first “full” restoration I’ve done
                    #263358
                    Sams Outboard
                      Thank you! It still isnt perfect but like I mentioned before I using this as a learning experience
                      • This reply was modified 4 years, 3 months ago by Sams Outboard.
                      #263363
                      Sams Outboard
                        Your saying you want me to fix them up?
