Home › Forum › Ask A Member › Etec 25 hp question
  • #21613
      OK, so you are saying that the EMM trouble codes are NOT tied into the system check gage? How are the trouble codes retrieved?
      Does this engine have a water separating filter, perhaps that is full of water.
      #21618
      willg
        There is no water separator on the engine, only a small inline filter before the vapor separator. Trouble codes are retrieved via Evinrude Diagnostics software on a laptop. And yes, trouble codes are stored in the EMM.
        #21620
          OK, so there is no way of knowing if codes are present without the software, correct?
          #21623
          willg
            Correct.
            #21624
            wedgie
              quote Mumbles:
              Hey Wedgie, would you get a promotion if you saved the company a bunch of $$$ by installing a regular carb on it to solve the problem? 💡
              No chance of promotion where I work unless you have the seniority. The manager where I work had 35 years in the union before he was offered to work for "the other side". Sure , he makes 20% more, but I doubt it would be worth the headaches. 🙁
              Would it even be possible to graft a carb on there. Too many electronics looking for feedback from sensors to make it run I’d imagine. :geek:
              So anyway, the Millwrights discovered a hole in the fuel lift pump diaphragm and have ordered a new one. I got this info second hand from the welding shop so can’t be sure my source is fully informed. Seems like an easy and relatively cheap fix.
              Thanks for the info everyone. I enjoy learning about the newer stuff too 🙂
              #21674
              willg
                Good to hear that it was a simple problem.
