Home › Forum › Ask A Member › Etec 25 hp question
- This topic has 15 replies, 6 voices, and was last updated 11 years, 3 months ago by
willg.
August 6, 2015 at 1:02 am #2198
Way too new for me. Etec e25dtelisc
Guys at work complaining their 25 hp Etec on their work boat will run at idle but will bog out and quite when they give it the gas. Left them stranded when they couldn’t get it re started and had to call for a tow. I didn’t have a chance to get any more details, but told them I would ask you guys about possible causes. I don’t think a suggestion of cleaning the carb will cut it this time π
Thanks, π
August 6, 2015 at 1:33 am #21566Tough to say what is wrong without looking at it in person, I would recommend bringing it to an Evinrude dealer to have them hook up Evinrude Diagnostics to it to see if there are any codes and check injector operation and fuel pressure. Before bringing it to them, check the basics such as fuel hose and primer ball condition and check to see if there is any water in the fuel.
August 6, 2015 at 1:45 am #21567Thanks Will,
Buddy said he thought it was not getting enough air, so he removed something and, I’m just guessing, it was the air silencer. He said it ran better for a while, then started acting up again. These guys are all pretty handy and knowledgeable with hydraulics and heavy machinery, but they came to me with this question and I was kinda hoping to at least narrow it down for them before they send it in.
So I take it the injector would be your first suspect Will ?
August 6, 2015 at 1:56 am #21569Tough to say. I haven’t worked on an etec with a hesitation problem yet, but it definitely sounds fuel related. As the injectors are part of the emissions control system, replacement must be done by a dealer and the injector coefficients that are loaded into the EMM (engine management module) must be updated or the powerhead could fail (blow up) due to a lean mixture.
August 6, 2015 at 2:04 am #21570Ok, I will tell them that .
I should just trade them for my ’68 ski twin, Updated with the Atom modules, and throw in a water pump change and tune up when needed π .
August 6, 2015 at 2:33 am #21573Wedgie, a 33hp? I want it, but Canada is too far away!
August 6, 2015 at 4:06 am #21578Hey Wedgie, would you get a promotion if you saved the company a bunch of $$$ by installing a regular carb on it to solve the problem? π‘
August 6, 2015 at 1:43 pm #21590quote WillG:As the injectors are part of the emissions control system, replacement must be done by a dealer and the injector coefficients that are loaded into the EMM (engine management module) must be updated or the powerhead could fail (blow up) due to a lean mixture.I continue to think the world will be better if we put all the people that charged us with "green engines" on a soap (biodegradable) boat in a sea full of shark… π π
August 6, 2015 at 4:16 pm #21598Will: Do these engine have any warning lights/horns that signal EMM trouble codes? Just thinking along the lines of water in the fuel, fuel restriction or air leaks.
August 6, 2015 at 4:51 pm #21602Don, on the 25/30 etec, the emm is so small that it only has the low oil and overheat warning functions for systemcheck.
