Home › Forum › Ask A Member › Elto Sportster Not Pumping Water
- This topic has 23 replies, 8 voices, and was last updated 11 years, 6 months ago by
legendre.
May 9, 2015 at 5:07 pm #15589quote legendre:quote pj43:quote legendre:Are you sure that the impeller is actually turning?
Have you blown out the water passages – both into and out of the water pump housing?
I’m pretty sure its turning but I don’t know how to check for sure. And as for the second part, sort of. I have put degreaser in the holes to make sure the was no oil blocking the tubes.
I don’t know enough about your specific motor to tell you how to verify impeller rotation – but if it’s gear-driven directly by the prop drive shaft, that’s another matter.
For anyone wondering, this is the impeller in my motor.
http://forums.iboats.com/filedata/fetch?id=6942799May 9, 2015 at 7:57 pm #15607I am not a omc man, But some of the early ones need to be moving to pump . won’t pump well in a test tank.
May 9, 2015 at 11:03 pm #15619That is the gale pump. Impeller is properly called a rotor. It must fit closely on the etcccentri c in the center and just touch the housing on one side. Other said side should have a space
May 9, 2015 at 11:26 pm #15620Anonymous
one reason why "wobbler" pumps stop is the rubber expanding (from saturation with grease):
the hole gets too large for the eccentric.In the US the "Sportster" was part of a short (one year?) post-WWII revival of the Elto brand.
In Canada, Elto was the equivalent of the Gale brand, and lasted longer (thru the 50’s?)May 10, 2015 at 1:01 am #15634OK – Here is the parts book …
A better view of the pump …
May 10, 2015 at 1:09 am #15636Johnson uses a similar rotor pump –
May 10, 2015 at 3:09 am #15646quote Phil B:one reason why “wobbler” pumps stop is the rubber expanding (from saturation with grease):
the hole gets too large for the eccentric.In the US the “Sportster” was part of a short (one year?) post-WWII revival of the Elto brand.
In Canada, Elto was the equivalent of the Gale brand, and lasted longer (thru the 50’s?)Yeah that may be the case. Do you know where I might be able to find one? (P.S. I think you are right, I’m pretty sure the Elto Sportsters were only made in 1949 and 1950.)
May 10, 2015 at 1:32 pm #15658try taking off the lower unit submerging and water and spinning the driveshaft with a drill to see if it is pumping water if It is when it’s either a seal or a blockage , I had a similar problem with Scott at water and it took me eight times to get it right 😎
May 10, 2015 at 9:28 pm #15678I was out in the woods when I made my previous post, doing it on a smart fone. Trying to type on that micro keyboard ain’t smart. Anyhoo, yes, grease is the culprit. It makes the rubber swell up and become useless. Club member Brian Wilcox makes nice reproductions ones. call 810-794-7685 before 8 pm EST please. Or email Baron0418@att.net. please note the b must be a capital.
May 11, 2015 at 12:59 am #15688Those ‘wobbler’ type pumps are among the simplest designs around, there’s not much to prevent them from working, other than excessive clearances – as others have noted.
I don’t mean to be insulting, but are you sure the little drive pin #550082 is in place? The pin is about 1/4" long, and inserts into the prop shaft. The eccentric #550085 then slides over the prop shaft, and has a machined groove to accept the drive pin. Finally, the rubber rotor (aka "wobbler") #550040 is fitted over the eccentric.
No pin = no eccentric rotation = no water flow. And they’re so easy to lose or just overlook.. Also, a missing gasket or intermediate plate will shut things down, too.
