Home › Forum › Ask A Member › Elto Sportster Not Pumping Water
Viewing 10 posts - 1 through 10 (of 24 total)
  • #1431
    pj43
      Hi everyone. I am pretty new to outboards and I just picked up an Elto Sportster. It doesn’t seem like there is too much info about them anywhere so hopefully someone can help me. The problem is that the outboard doesn’t pump water. It has an impellar in good shape, but for some reason it won’t pump water. Does anyone know why?
      #15508
      Randy in Tampa
        What year model is it?
        #15530
        pj43
          quote Randy in Tampa:
          Its a 1949 4432
          #15534
          legendre
            Are you sure that the impeller is actually turning?
            Have you blown out the water passages – both into and out of the water pump housing?
            #15536
              Running in a barrel or on a boat?
              #15549
              pj43
                quote Chris_P:
                Its running in a bucket, but there was plenty of water to cover the inlet holes.
                #15550
                pj43
                  quote legendre:
                  I’m pretty sure its turning but I don’t know how to check for sure. And as for the second part, sort of. I have put degreaser in the holes to make sure the was no oil blocking the tubes.
                  #15552
                  legendre
                    quote pj43:
                    quote legendre:
                    I don’t know enough about your specific motor to tell you how to verify impeller rotation – but if it’s gear-driven directly by the prop drive shaft, that’s another matter.
                    #15554
                      You may need it deeper in the water. The pump is not self priming, needs to be completely submerged.
                      #15587
                      pj43
                        quote Chris_P:
                        The inlet holes are in the prop, and the prop was all the way submerged, so I don’t think that is the problem.
