Home › Forum › Ask A Member › Carb Dip Solution Troubles
  • #29633
    dave-schinkel
      Just wanted to let anyone know that uses this carb dip. I had two cans of this stuff over the years and both ate through the bottom of the can a short time after cleaning some parts. I used a new metal paint can the second time it happened and it seemed to hold up. I got rid of it because when it leaks it will stink forever. There was another brand I used years ago that was less smelly and never ate the can, It might have been Gum Out.
      #29711
      weedlessdrive
        The little ultra sonic jewelry cleaners with hot water and pinsol or soap work great. Everything comes out looking brand new it’s amazing.
        #29712
        elgin2
          I use Pine-Sol full strength in a old Crock-Pot.Works great and wont eat up any seals. And makes the garage smell clean.
          quote Ken W:
          I love to use 50/50 Pinesol and hot water.
          #30033
          John
            DIY Ultra Sonic Cleaner: Secure a palm sander to the can of cleaner. (tape, bungee cord, inner tube band, etc.)
            Hang the can with a string from your work bench to provide maximum vibration. Keep the lid on.
            some of the newer gallon paint cans are all plastic now. Most are going with at least a plastic bottom.
            so keep an eye out for one that could replace the factory tin coated can.
            I have a 40 year old sharpening stone that has been used with oil . . . has not been used in 30 years
            and wanted to remove the gunk . . . well, a few days soaking in Parts Cleaner worked quite well.
            After several good rinses, boiled it in Dawn dish soap and more gunk came out.
            Now, it is like new, BUT – it stinks to High Heaven like the parts cleaner !!! It is hanging on the clothes line
            with a string hoping that time will eliminate the lingering stink. I will be using water this time as the lubricant – not oil.
            * and according to my nose, Pinesol stinks just as bad as the parts cleaner – so I don’t use it. (anywhere).
            #30034
              These DIY homemade ones might be Sonic but I’m not sure about Ultra.
              https://www.youtube.com/watch?v=6cSdL7I4AHM
              https://www.youtube.com/watch?v=EKPKbSUCZIE
