Home › Forum › Ask A Member › Carb Dip Solution Troubles
  • #3282
    david-bartlett
      I recently took the carb of a 1948 Evinrude SpeediTwin project that I have going and took it apart for cleaning. Lots of nasty crud and varnish inside so I put it in a can of Carb Dip. Just before I closed the lid, I tossed the brass float in as well.
      I forgot about it for a couple days, then took the pieces out of the solution and rinsed them off. The float now had liquid INSIDE!!!
      At first I thought it was a pin hole, but the card dip actually corroded the brass to the point of making it brittle and porous. Now I need a new float!
      Just want to post this so others will not make the same mistake.
      Anybody want a can of Carb Dip?? 😎
      #29328
      wedgie
        I think it was Gary S. that warned of putting the sintered fuel filters in carb cleaner as it will turn those to powder also. 🙁
        #29329
        david-bartlett
          Wedgie,
          Yes, I knew that also. Won’t do it again.
          #29330
            Wedjie,
            I use air conditioning coil cleaner for filters. It’s made to spray on the aluminum evaporator coils inside the AC unit. Fill a old pill bottle & let it sit for a few days, then flush with water. It does a great job! The cleaner is bright green in a plastic bottle sold at AC contractors supply.
            #29342
            Leon
              Wow! What kind of carb cleaner was it? I’ve never seen anything that strong yet.
              #29346
                I want some! The new stuff doesn’t even come close to the old stuff!
                #29366
                david-bartlett
                  quote 1946Zephyr:
                  It was "Berrymans". Right off the shelf at Wally-World.
                  #29397
                  Leon
                    Cool. I’m going to get some 🙂
                    #29399
                      ebay has it at about $23.00 free shipping.
                      #29472
                      ken-w
                        I love to use 50/50 Pinesol and hot water.
