Home › Forum › Ask A Member › burning 2 cycle mix gas in your truck?
Viewing 10 posts - 11 through 20 (of 25 total)
  • #47515
      with Stabil or likewise products it will burn ok in the lawn tools next year
      been doing this for over 30 years with no complaints from the tractor, mower, blower and trimmer
      #47519
      boxcar
        The cat may or may not like the oil. But fuel injectors will hate it. I’d run it through the mower etc. If you decide to run it through your cars engine and it is injected, my shop hours are 8-5.
        #47522
        RICHARD A. WHITE
          I run it thru my snow blower, lawn mower and weed eater…acts a little funky but it runs…
          classicomctools@gmail.com
          #47527
          mr-asa
            quote BillW:
            Just to throw some proverbial gas in the fire here, today’s Mercruiser stern drives with fuel injection AND CATS call for a winterizing mix of fuel stabilizer, plus TWO QUARTS of TCW-3 oil, per six gallons of gas. That’s like 12:1, isn’t it? To me, this means the cats should be able to tolerate oil. They mostly don’t like misfire. I would bet a nickle that if you dilute with more straight gas, you’ll be alright…..However, have have not tried it myself.
            Those cats are designed for it. Automotive cats are not.
            Also, a winterizing mix meaning it’s going to be stored? Not run on regularly? Completely different scenario
            #47535
            PugetSoundBoater
              quote boxcar:
              This is why i have not put the fuel mix in my 4 cylinder fuel injected . I have other plans between 8 and 5. 😀
              Robbie Robertson
              #47541
                quote Mr. Asa:
                quote BillW:
                I knew, knew, KNEW I should have kept out of this one.
                #47551
                collectorinspector
                  quote boxcar:
                  Do you do mobile work?
                  BnC
                  #47553
                  Pete
                    Do it at about 1 gallon at a time to your truck tank when filling up, the 1 gallon at 50:1 added to a 15 gallon mix will dilute the total to 750:1 and as Tubs says if just regular outboard oil should be OK.
                    #47557
                    RICHARD A. WHITE
                      So those that run Synthetic mix… still ok?
                      #47560
                        If synthetics were a problem they wouldn’t be sold
                        to be used in motors with a converter.
                        Even though we are talking about 4 stroke motors
                        some oil passes through the converter. The amount
                        depends on the age and condition of the motor.
                        In older motors that use a considerable amount of
                        oil they still don’t smoke as the oil is burned up in
                        the converter. That what its there for. Now if you
                        get to the point where the converter is getting more
                        oil than it can process it could become blocked
                        but that would be way more than what your
                        thinking about adding. Some of the oil your adding
                        will be burned during combustion. What remains
                        will be burned up by the converter.
