Home › Forum › Ask A Member › burning 2 cycle mix gas in your truck?
  • #5704
    boatman
      Hi,
      Took the Lone Star with the 100 hp Johnson out for its last run of the year today. Couldn’t pass it up- mid 60s here in Chicago. Ran out of sunlight before I ran out of gas. Have 5 gallons with 50/1 mix in it. I have Stabil in it and could store it for the winter, but I prefer to get rid of it. Anybody run it through their car? Any ill effects?
      Thanks,
      Paul
      #47496
      nali
        I don’t see why it could be a problem.
        #47497
        reivertom
          It depends what car you put it in. If it is an older car without the computers, it will just smoke a bit, but a computerized ignition maybe have a problem. I don’t know about injectors either….just a thought.
          #47498
          david-bartlett
            5 gallons of 50:1 in a pretty full tank should not cause any issues. I run it through my car or lawn tractor to use it up.
            #47499
            PugetSoundBoater
              I used to dump remaining 1-2 gallons 50:1 in my 1971 F 250 at the end of the season, never had a problem. The truck had twin 20 gallon tanks, and i would add some pump gas to it also. With the computers today,outboard mix may trip the check engine light? I’ve been reluctant to putting outboard gas in my Isuzu Hombre(S 10 ) with a 4 cylinder,but i’ve sure thought about it.
              Robbie Robertson
              #47501
              boatman
                Yeah, I usually run it through the lawn mower and snow blower, but have too much to use up that way this year.
                #47503
                mr-asa
                  You’ll clog your catalytic converters if you do it all at once. Better to just save it till next season
                  #47504
                  kees
                    International Member
                    quote Mr. Asa:
                    agree, using it in an old car only I see no problems, if you have a catalytic converter,
                    then you run into troubles
                    #47505
                      Just to throw some proverbial gas in the fire here, today’s Mercruiser stern drives with fuel injection AND CATS call for a winterizing mix of fuel stabilizer, plus TWO QUARTS of TCW-3 oil, per six gallons of gas. That’s like 12:1, isn’t it? To me, this means the cats should be able to tolerate oil. They mostly don’t like misfire. I would bet a nickle that if you dilute with more straight gas, you’ll be alright…..However, have have not tried it myself.
                      #47511
                        Oil comes from the same hole in the ground as
                        the gasoline so the oil itself isn’t a problem.
                        Additives in the oil is where you could have an
                        issue if you happen to be using up older oil
                        which had zinc or lead in it. The metals that
                        would clog up converters are only found in
                        specialty oils normally used in competition
                        today so unless you have been using one of
                        them you shouldn’t any problems.
