Home › Forum › Ask A Member › BIg booboo :-( ….wisdoom needed
  • #273171
      Labrador Guy…. used you suggestion … found   1/4 inch diameter    Allen head bolt  with  fine (28) threads  fits perfectly.
      So I’ll grind down the unused threads.  Allen head sticks out a bit but will be better than my  junked pivot pin.  I’ll shave some metal on the socket  part of the bolt  to thin it down a bit.
      #273172
        Since I can’t edit  previous….  found these on Amazon
        not cheap but should fit even better  with less bolt  head sticking out .
        Pivot pins are not  expensive in USA  but with shipping fees to Canada and exchange I’ll use these  and have spares in the parts box 🙂
        Hard-to-Find Fastener 014973200473 Phillips Pan Machine Screws, 1/4-28 x 2, Piece-5, Machine Screws – Amazon Canada
        #273178
        Dale
          Sounds like a plan!
          dale
