Home › Forum › Ask A Member › BIg booboo :-( ….wisdoom needed
- This topic has 12 replies, 5 voices, and was last updated 3 years, 8 months ago by
Dale.
February 24, 2023 at 4:08 pm #273102
I had to take appart…a second time……. my sealed gearcase on a cd17-18
whenIwent to remove the Philipps head pivot pit #38 on the shift rod I stripped it OMG!!!!
I tried to saw a slot and use a flat screwdriver to no avail…..got worse and worse… not pretty
So….. anyboby have suggestion for me for removing a maggled philips headed bolt before I move on to drilling …..
I had screwed it down what seemsed to be normally…. with a dab of gasket (Permatex black) goo to seal it but it looks like that was my mistake.
and…. will be looking for a spare pivot bolt if I sane the housing threads
I’ll try anything.. thanks
February 24, 2023 at 4:10 pm #273103edit…
and…. will be looking for a spare pivot bolt if I save the housing threads
February 24, 2023 at 4:23 pm #273104I suppose it’s too late to try a hand impact screwdriver? Unless somebody has a better suggestion, how about a left hand drill bit?
P.S. don’t feel bad. I’ve had the same situation.
February 24, 2023 at 4:40 pm #273105tried impact… no go will try left hand drill ( to be purchased…) I’ll see if anyone else comes up with a cure
thanks
February 24, 2023 at 6:53 pm #273127Do you have a Dremel? If so, you can cut a slot in the head to accept a flat head screwdriver or a bit for your impact. If the head is really bad, they can be removed by carefully working the outside edge with a small and sharp cold chisel. Bin der, dun dat.
I don’t really know what they were thinking when they made these screws with a tiny Phillips socket. Maybe the designer was an ex watch maker? If they had used the proven Robertson socket, the screw could be removed a kazillion times and reused instead of stripping out on a first attempt and necessitating the purchase of a new one. Or maybe that’s what the original plan was.
February 24, 2023 at 7:19 pm #273128crosbyman back when I was a pup we had problems just like yours with motorcycle case screws. We used a center punch. Find a spot on the head a little off center drive the center punch into the head until you have a small divot. Next tilt the punch a little to turn the screw counter clockwise. Medium size hammer and Maybe you will get lucky and it might turn for you! This trick worked miracles for us sometimes.
dale
February 24, 2023 at 8:08 pm #273129ok will try … off to the basement 🙂
February 24, 2023 at 8:22 pm #273130Gentlemen….. we have success & it took 2 minutes with a real pointy nail set punch. I figured the circular edge of the nail set punch woud grab the bolt head better and BINGO… movement.. after 3-4 wacks
I can now move on to resealing the GC which needed a shift rod oring , propr shaft and… drive shaft seals.
thanks for sharing your experience 🙂
February 24, 2023 at 8:42 pm #273131Hey! That’s great to hear! BTW you can make one of those pivot bolts. Just need a bolt or a screw with the proper tread. Carefully grind or file the treads off the end that goes into the shift fork and housing. Don’t ask me how I know this. Some of us are pretty cheap I guess!
can a corn!
dale
February 24, 2023 at 9:04 pm #273132Glad it came to a quick and easy resolution. Always feels great when you finally remove a broken, seized or stripped screw or bolt!
"Every time you remove a broken or seized bolt an angel gets his wings." -
