Home › Forum › Ask A Member › Battery powered ignition
- This topic has 17 replies, 5 voices, and was last updated 3 years ago by
Jeff Heise.
October 8, 2023 at 9:54 am #281434
Recently aquired a omc serial number 4010715 i damaged one of the plug wires trying to remove the plugs is there a replacement coil available? also mounting bracket is broke on one end , never dealt with battery ignition before what kind of battery would i need ? Can send pics if needed
With no pictures I am not sure which coil you have, but guessing it is the one that has 2 brackets on the outside to use to attach to mounting bosses on the motor….I do 3 d printing and I am currently designing Resin printed tube to allow a modern coil to be installed that will fit in this application.. I have 2 motors here one is a 1934 Speeditwin, the other is a 1933 Elto Lightweight Model # 444. Both use this type of coil…
The system will allow easy access to let one replace the coil, plug wires and such without dealing with that blasted nasty tar…
I am making progress…
Cheers
Richard
Will post pics later todsy
Tried posting pics. Says file too large. Yes. My coil is just over 5″
October 8, 2023 at 9:55 am #281435
Manny of us use this type of battery-
https://www.ebay.com/itm/222528177276?mkcid=16&mkevt=1&mkrid=711-127632-2357-0&ssspo=FmWitaJLQCa&sssrc=2047675&ssuid=_-YLkpExSsW&widget_ver=artemis&media=COPY
You can repair your coil using this coil-
https://www.ebay.com/itm/232218550107
using this procedure-
Video – 1 https://www.youtube.com/watch?v=e2vxDqF_OEU
Video – 2 https://youtu.be/xwbTlC1xIlA?si=_Yfb1wQD6iV513Tx
Tubs.Mine is just over 5″ how would this work
October 8, 2023 at 12:01 pm #281438
I’ll get the measurements of the replacement coil and post them here by tomorrow.
October 8, 2023 at 10:12 pm #281452
These are the coil dimension. Your OK length wise.
It would be a tight fit if your coil tube dia, is the same as this one.
Tubs.
October 9, 2023 at 10:25 pm #281504October 10, 2023 at 7:23 am #281507That’d be fine by me. Never seen a coil like that
